Re: Tools for cutting fiberglass.
[Re: mopar dave]
#2813938
08/27/20 01:53 PM
08/27/20 01:53 PM
Posts: 22,724 Bitopia
jcc
Bitopia
Your initial idea would work,. How accurate do cuts need to be? Sometimes when I'm doing a an accurate cut, its worth fabbing a template and using a wood router worth a carbide bit. The biggest headache is all the FG dust you will be creating. Suggest doing outside, in the grass, not upwind of any openings. The dust never decomposes, and itches forever when disturbed in a slight wind, and goggles, gloves, disposable body suit, etc. you have been warned.
[Re: mopar dave]
#2813946
08/27/20 02:19 PM
08/27/20 02:19 PM
Posts: 1,443 central ohio
nss guy
central ohio
Roto Zip with circle attachment if it's a fiberglass hood
[Re: jcc]
#2813950
08/27/20 02:22 PM
08/27/20 02:22 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I used a Jigsaw on mine. The dust wasn't bad at all.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2813951
08/27/20 02:24 PM
08/27/20 02:24 PM
Posts: 10,046 MN
JERICOGTX
MN
I used a Jigsaw on mine. The dust wasn't bad at all. Jigsaw works the best. Leave a little wiggle room, and finish off with a flap wheel on the grinder. I'll be working on my hood tonight...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2813954
08/27/20 02:36 PM
08/27/20 02:36 PM
Posts: 30,474 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
I used a Jigsaw on mine. The dust wasn't bad at all. Jigsaw works the best. Leave a little wiggle room, and finish off with a flap wheel on the grinder. I'll be working on my hood tonight... A variable speed saber saw on sloooower speed..., FG dust ? .... whata buncha wimps ! larryLOVEit and I luv the smell of that dust in the morning..... It tastes like VICTORY!
[Re: mopar dave]
#2813957
08/27/20 02:44 PM
08/27/20 02:44 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I will be getting started soon on my T ram project on the Barracuda. My AAR(stingerfiberglass) hood will be here tomorrow. The flat hood will need to be cut to fit the carbs up thru. Need some advise on best tools or technique on cutting the hole in this hood. Thought I might use a hole saw for the corners and maybe a pneumatic cut off tool with the guard for the straight lines. All opinions welcomed. Thanks a small 3" cutting wheel will be smooth and no vibration like a jig saw.
[Re: burdar]
#2813959
08/27/20 02:48 PM
08/27/20 02:48 PM
Posts: 10,046 MN
JERICOGTX
MN
Tried it. Threw mine in the garbage after it barely worked.
69 GTX
68 Road Runner
[Re: dOc !]
#2814029
08/27/20 06:26 PM
08/27/20 06:26 PM
Posts: 11,694 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I used a Jigsaw on mine. The dust wasn't bad at all. Jigsaw works the best. Leave a little wiggle room, and finish off with a flap wheel on the grinder. I'll be working on my hood tonight... A variable speed saber saw on sloooower speed..., FG dust ? .... whata buncha wimps ! larryLOVEit and I luv the smell of that dust in the morning..... It tastes like VICTORY! I hear it causes brain damage after a while. And drooling.
[Re: burdar]
#2814032
08/27/20 06:31 PM
08/27/20 06:31 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
That's a good tool for sheetmetal, plastic, fiberglass. A good one is more than $26 and the blades aren't cheap. Forget about using it on anything thick.
[Re: dOc !]
#2814035
08/27/20 06:35 PM
08/27/20 06:35 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Well seaMac ... what caused yur drain bamage and ? Parts cleaner, the good old green stuff back in the old days, with no gloves. None of this sissy stuff. And bad females.
[Re: CMcAllister]
#2814036
08/27/20 06:42 PM
08/27/20 06:42 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I never try to hit my spots with an initial cut on fiberglass. Masking tape, lay it out, rough it and use a disc grinder or a 3" angle grinder with an 80 disc or a scotchbrite pad. A file and paper by hand to finish it
Dirty? H3ii yes. But the results are nice if you take your time. I've seen some of this stuff look like somebody used a hatchet on it.
