Are disc brake b bodies wider than drums? #2814718
08/29/20 01:23 PM
08/29/20 01:23 PM
Indiana
68_661charger Offline OP
Indiana
Ive heard disc brakes are a wider setup from wheel mounting surface to surface over drums. True? How much? 68 b body....
Re: Are disc brake b bodies wider than drums? [Re: 68_661charger] #2814739
08/29/20 01:51 PM
08/29/20 01:51 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Seems to depend on what setup you use.
I used an aftermarket conversion on a '63 and it did widen the front track, about 3/4" each side.
The all-Mopar conversion on my '68 RR seems same as drums but haven't measured it.
Re: Are disc brake b bodies wider than drums? [Re: topside] #2814749
08/29/20 02:31 PM
08/29/20 02:31 PM
Andrewh Offline
Andrewh  Offline
yeah like scaredbird or similar conversions that use drum spindles, tend to push out the width.
stock should be the same.
Re: Are disc brake b bodies wider than drums? [Re: Andrewh] #2814764
08/29/20 03:08 PM
08/29/20 03:08 PM
Indiana
Indiana
Yes Im using the all mopar factory stuff. A and E body type spindles.
Re: Are disc brake b bodies wider than drums? [Re: 68_661charger] #2815115
08/30/20 01:48 PM
08/30/20 01:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The B-body swaps I've done using factory A-body spindles increased the track width 5/16" per side.
