Brake piston compressor #2813720
08/26/20 09:16 PM
08/26/20 09:16 PM
Kentucky
dfsmopars Offline OP
Kentucky
What’s the preferred style of brake piston compressor for disc brakes? Is there a brand that is preferred as well. This is not for a business but a serious hobbiest.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Brake piston compressor [Re: dfsmopars] #2813721
08/26/20 09:16 PM
08/26/20 09:16 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Basic C clamp.
Re: Brake piston compressor [Re: stumpy] #2813738
08/26/20 09:38 PM
08/26/20 09:38 PM
Kentucky
Kentucky
Well, it’s a little different with rear brakes with electric e- brake. Found out tonight.
Re: Brake piston compressor [Re: stumpy] #2813740
08/26/20 09:39 PM
08/26/20 09:39 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Originally Posted by stumpy
Basic C clamp.
That is what I use with an old pad
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Brake piston compressor [Re: dfsmopars] #2813746
08/26/20 09:47 PM
08/26/20 09:47 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
Several manufacturers sell tools to rotate rear brake pistons as most rear caliper pistons rotate in instead of press in.
Lisle sells a universal cube shaped tool that works on many. For my Dart I was able to rotate the pistons to retract in using a needle nose pliers.
Re: Brake piston compressor [Re: Mastershake340] #2813761
08/26/20 10:11 PM
08/26/20 10:11 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I used to use a c-clamp myself, until doing my wife's Edge brakes over the winter. You have to turn the piston clockwise while pushing in, so you need a special compressor for that. Go on Amazon - there are many of these tool sets for around $22.00, & they will last a lifetime. I bought one & now wonder how I ever went without it! WAY easier than a c-clamp, & much more versatile.
Re: Brake piston compressor [Re: stumpy] #2813795
08/26/20 11:10 PM
08/26/20 11:10 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
Basic C clamp.
Yes .. but a BIGGY one ! ...
But NOW that I’ve got reman calipers on my carrotvan... I won’t be needing it that often ... HOPEFULLY
Re: Brake piston compressor [Re: dOoC] #2813838
08/27/20 07:40 AM
08/27/20 07:40 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Last I saw, Lisle tool company makes several different "hand gun" style compressors, I've had one for single piston calipers for 20 years, its awesome and way easier to use than a c clamp ( as strange as that sounds), and they make the compressor for multi-piston as well.
Re: Brake piston compressor [Re: moparjim79] #2813839
08/27/20 07:44 AM
08/27/20 07:44 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
on compressing regular disc brake pistons i use a big Chanel lock pliers or a "C" clamp vice grips.
i have also just stuck a screwdriver between a brake pad and the rotor and pried the piston in a bit. then removed the caliper and 1 pad on the non piston side. re install caliper, stuck the screwdriver in big gap and press the piston back in..
NOTE when i do all of the above. i loosen the bleeder screw so when i compress the piston in the fluid goes out the bleeder, the piston compresses easily compared to not opening the bleeder and i don't force dirty fluid back into the master cylinder
from what i have READ, i hasn't used this tool. the HF tool works pretty good when pressing in rear disc brake pistons with E brake that's part of the rear caliper..
https://www.harborfreight.com/disc-...html?_br_psugg_q=disc+brake+caliper+tool
perception is 90% of reality
Re: Brake piston compressor [Re: moparjim79] #2813841
08/27/20 07:57 AM
08/27/20 07:57 AM
Mr T2U Offline
Mr T2U  Offline
for multiple piston calipers, especially fixed one, this is the best tool to use.
Re: Brake piston compressor [Re: Mr T2U] #2813879
08/27/20 09:55 AM
08/27/20 09:55 AM
pennsylvania
poboyengineering Offline
pennsylvania
For years, I used a C-clamp and pliers to twist the piston in, but last year I bought the HF tool. Why did I wait so long?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Brake piston compressor [Re: poboyengineering] #2813881
08/27/20 10:00 AM
08/27/20 10:00 AM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
Another option that I use is a steering wheel/balancer puller, it works great to press the piston back into the caliper.
Re: Brake piston compressor [Re: Sunroofcuda] #2813884
08/27/20 10:25 AM
08/27/20 10:25 AM
340SIX Offline
340SIX  Offline
That is on the deaths of my new car as well Harbor Freight was the place i got mine
Re: Brake piston compressor [Re: Mr T2U] #2814097
08/27/20 08:58 PM
08/27/20 08:58 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
I need this
Re: Brake piston compressor [Re: moparjim79] #2814104
08/27/20 09:52 PM
08/27/20 09:52 PM
Florida STAYcation
Florida STAYcation
ROTATING the piston while pushing it in ? ...
FIRST TIME I’ve heard this concept and I started a topic about FWD calipers sticking BADLY ...
Re: Brake piston compressor [Re: dOoC] #2814140
08/27/20 10:53 PM
08/27/20 10:53 PM
5thAve Offline
5thAve  Offline
I also always did it the big C clamp way. Not too fun on a car with muli piston calipers they always try to teetertotter.
Re: Brake piston compressor [Re: Mr T2U] #2814144
08/27/20 11:03 PM
08/27/20 11:03 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I checked out the Harbor Freight kit - not nearly as good of a kit or a deal as this:
Re: Brake piston compressor [Re: 5thAve] #2814149
08/27/20 11:11 PM
08/27/20 11:11 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Even with an old brake pad in place to press on?
I use this basic NAPA piece
https://www.napaonline.com/en/p/BK_...JHJrY6c5fuVXC6mGOhsYD354hZAaAhc-EALw_wcB
Ride eternal, shiny and chrome
Re: Brake piston compressor [Re: DirectSubjection] #2814152
08/27/20 11:13 PM
08/27/20 11:13 PM
Here
Here
Re: Brake piston compressor [Re: Sunroofcuda] #2814154
08/27/20 11:16 PM
08/27/20 11:16 PM
Florida STAYcation
Florida STAYcation
SunnyRuff ... hood find .. here’s it on eBay ... prefer not dealing with Amazon down
