Schumacher Torque Strap Question #281267
04/08/09 09:54 AM
04/08/09 09:54 AM
U.S.
moparniac Offline OP
U.S.
Has anyone ran one on both sides of the K member??? dont see why you couldny ...
Mopar Performance
Re: Schumacher Torque Strap Question [Re: moparniac] #281268
04/08/09 10:37 AM
04/08/09 10:37 AM
South Carolina, United States
carolinacuda Offline
Never tried them on both sides. I have put it on da driver's side and Im on my second one. The first one broke (actually it was the bracket on the strap not the strap itself) after the Schumacher poly motor mount broke. Dont know why u would need one on da pass side. The motor lifts from the drivers side when you accelerate, unless your in reverse.
Re: Schumacher Torque Strap Question [Re: carolinacuda] #281269
04/08/09 12:04 PM
04/08/09 12:04 PM
U.S.
U.S.
was thinking to make it stronger and less stress on the dr side one also...
Mopar Performance
Re: Schumacher Torque Strap Question [Re: moparniac] #281270
04/08/09 12:08 PM
04/08/09 12:08 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
It's cheaper to make your own
You only need one on the drivers side.
Put a engine plate in it if your worried about twisting
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Schumacher Torque Strap Question [Re: moparniac] #281271
04/08/09 04:45 PM
04/08/09 04:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you talking a torque strap or a torque reaction rod
(strap going down on a angle to the frame, almost
vertical) or (a torque reaction rod, almost fore and aft)
The Strap is to take the load off of a motor mount
and you only need 1, the passenger side doesnt get
any real load UNLESS you break the drivers side mount.
The rods keep the engine from going rearward on launch
with a motor plate
Re: Schumacher Torque Strap Question [Re: MR_P_BODY] #281272
04/08/09 04:58 PM
04/08/09 04:58 PM
U.S.
U.S.
I understand mr P body but wouldnt one on the pass side help with the twisting and take some pressure off the drivers side... the strap now...
Dont really wanna run a motor plate. doesnt fit the theme of my car
Mopar Performance
Re: Schumacher Torque Strap Question [Re: moparniac] #281273
04/08/09 05:08 PM
04/08/09 05:08 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
If you already have one, Find something else to spend $90 on
If not buy one for the drivers side and that will be more than plenty. Or make your own
SDG Motorsports
Re: Schumacher Torque Strap Question [Re: moparniac] #281274
04/08/09 05:13 PM
04/08/09 05:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The passenger side is basically in compression so you
can put a strap on it all day long and it wont do
diddly squat
Re: Schumacher Torque Strap Question [Re: DemonDust] #281275
04/08/09 05:14 PM
04/08/09 05:14 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
How about a solid mount on the drivers side? Seems like the simplest and most bulletproof method short of an engine mounting plate.
