Re: Schumacher Torque Strap Question
[Re: carolinacuda]
#281269
04/08/09 12:04 PM
04/08/09 12:04 PM
Posts: 6,295 U.S.
moparniac
U.S.
was thinking to make it stronger and less stress on the dr side one also...
Mopar Performance
[Re: moparniac]
#281271
04/08/09 04:45 PM
04/08/09 04:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Has anyone ran one on both sides of the K member??? dont see why you couldny ...
Are you talking a torque strap or a torque reaction rod (strap going down on a angle to the frame, almost vertical) or (a torque reaction rod, almost fore and aft) The Strap is to take the load off of a motor mount and you only need 1, the passenger side doesnt get any real load UNLESS you break the drivers side mount. The rods keep the engine from going rearward on launch with a motor plate
[Re: MR_P_BODY]
#281272
04/08/09 04:58 PM
04/08/09 04:58 PM
Posts: 6,295 U.S.
moparniac
U.S.
I understand mr P body but wouldnt one on the pass side help with the twisting and take some pressure off the drivers side... the strap now... Dont really wanna run a motor plate. doesnt fit the theme of my car
Mopar Performance
[Re: moparniac]
#281274
04/08/09 05:13 PM
04/08/09 05:13 PM
MR_P_BODY
The passenger side is basically in compression so you can put a strap on it all day long and it wont do diddly squat
