Drum brake self adjusters question #2810842
08/19/20 08:39 PM
08/19/20 08:39 PM
WASHINGTON, PA
11secaarcuda Offline OP
WASHINGTON, PA
OK, so I put new brakes and hardware on my Cuda, and it seems like the drums keep tightening up when I drive it. Is it possible that I made a mistake and put the threaded adjusters on wrong? Can anyone verify the orientation? 1970 AAR Cuda rear drum brakes. Pictures would be helpful too.
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: Drum brake self adjusters question [Re: 11secaarcuda] #2810847
08/19/20 08:53 PM
08/19/20 08:53 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
there is a right and and left side adjuster and if you put them on the wrong sides it will do what you are seeing.
Might need to double check you have them on the correct sides.
Shoot a pic of your setup and post it.
Re: Drum brake self adjusters question [Re: 11secaarcuda] #2810856
08/19/20 09:28 PM
08/19/20 09:28 PM
you want the left hand thread adjuster on the drivers side. the left hand threads are angled, easily ID'd by a quick visual
Re: Drum brake self adjusters question [Re: RapidRobert] #2810957
08/20/20 08:06 AM
08/20/20 08:06 AM
E
earlymopar Offline
earlymopar  Offline
E
Both left and right are angled but they are angled in opposite directions. The angle is called the "lead" of the thread.
