holley six pack fuel inlet nut wrench #2808020
08/12/20 11:20 AM
08/12/20 11:20 AM
Just South of The Motor City
limechallenger Offline OP
Ok , so I got a 340 sixpack in my 70 Challenger T/A. The accelerator pump blew out and I need to replace it! So as I try to get the carbs off I unfortunately kinked the center carb fuel line. the inlet fuel bowl nut turned and not the fuel line nut! I've tried every wrench in my box and cant get anything on it to hold it while I loosen the line nut! Does anyone know if there is a special wrench available to make thin job easier?
p.s. I will be ordering a new set of stainless lines for re installation
70 T/A Challenger 78 Aspen R/T 87 Indy 500 Dakota
Re: holley six pack fuel inlet nut wrench [Re: limechallenger] #2808023
08/12/20 11:23 AM
08/12/20 11:23 AM
Try removing the front carb first and then use a crescent wrench to hold the fuel bowl fitting so you can use a tubing wrench on the fuel line fitting to loosen it scope wrench up
Re: holley six pack fuel inlet nut wrench [Re: Cab_Burge] #2808033
08/12/20 11:43 AM
08/12/20 11:43 AM
That's part of my problem, I can't get the front carb off because the center carb fuel line is in the way!
Re: holley six pack fuel inlet nut wrench [Re: limechallenger] #2808045
08/12/20 11:55 AM
08/12/20 11:55 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Since you have already jacked it, needle nose vise grips tight and whack with small hammer.
If you are using org. lines and want to keep that look Ive a few spare sections.
You may remove the linkage clip and the 4 vac pod screws on the front pod to get at it better, just dont lose the small gasket from the pod to carb.
Id just cut the line out. Remove your front vac pod.
STOP POTATO HATE!
Re: holley six pack fuel inlet nut wrench [Re: Mr PotatoHead] #2808075
08/12/20 12:47 PM
08/12/20 12:47 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Working on the fuel line of a six pack is probably the biggest drawback of owning one.
Re: holley six pack fuel inlet nut wrench [Re: fastmark] #2808077
08/12/20 12:50 PM
08/12/20 12:50 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Take off the rear carb and then you can take the center off.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: holley six pack fuel inlet nut wrench [Re: 70sixpkrt] #2808102
08/12/20 02:05 PM
08/12/20 02:05 PM
WA
tman Offline
tman  Offline
WA
For me I remove the line from the distribution block and leave it on the carb inlet. When the carb is out, then you can remove the inlet lines if you need to.
Re: holley six pack fuel inlet nut wrench [Re: tman] #2808111
08/12/20 02:24 PM
08/12/20 02:24 PM
70sixpkrt Offline
70sixpkrt  Offline
Just like this.
4-speed
3:54 Dana
Re: holley six pack fuel inlet nut wrench [Re: 70sixpkrt] #2808116
08/12/20 02:36 PM
08/12/20 02:36 PM
WA
tman Offline
tman  Offline
WA
Just like this.
You got that right!
Re: holley six pack fuel inlet nut wrench [Re: limechallenger] #2808136
08/12/20 03:36 PM
08/12/20 03:36 PM
Try loosening all the bottom fittings next to see if you can swing them out of your way scope wrench luck
Oops, I should have read all the other replies instead of jumping in first blush
Re: holley six pack fuel inlet nut wrench [Re: Cab_Burge] #2808158
08/12/20 04:39 PM
08/12/20 04:39 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
I have a big blade screwdriver just for that reason.
Used it many times.
Re: holley six pack fuel inlet nut wrench [Re: KillerBee] #2808169
08/12/20 05:13 PM
08/12/20 05:13 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I kind of think that if you buy stainless lines they are tough to seal.Heck,the mild steel are bad enough. twocents
Re: holley six pack fuel inlet nut wrench [Re: KillerBee] #2808174
08/12/20 05:40 PM
08/12/20 05:40 PM
Richmond Twp. Mi.
Mr340 Online content
Mr340  Online Content
Richmond Twp. Mi.
Used it many times.
iagree
maybe this for reinstall
https://www.holley.com/blog/post/revamp_your_old_six_pack_setup_/
Re: holley six pack fuel inlet nut wrench [Re: 5carguy] #2808209
08/12/20 07:50 PM
08/12/20 07:50 PM
That's a good point, maybe I should consider going back to factory correct!
Re: holley six pack fuel inlet nut wrench [Re: Mr PotatoHead] #2808234
08/12/20 09:15 PM
08/12/20 09:15 PM
Those look like Stainless lines if they are did you have any leakage problems?
Re: holley six pack fuel inlet nut wrench [Re: limechallenger] #2808241
08/12/20 09:40 PM
08/12/20 09:40 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
Ive never had no issues with the SS, just like SS brake lines we all have different methods.
I do use good wrenches, and I will seat them hard one time and back off and re tighten. It helps if you can leave the carbs a hair loose and let the lines find a happy spot then tighten carbs. But again, everyone is different.
I bought several sets of the SS lines off ebay when inline tube dumped there stock for $25 shipped, the flippers bought hundreds of them and now they are hoping people forget as they are creeping the prices back way up.
So if you can shop around, everyone paid the same.
STOP POTATO HATE!
Re: holley six pack fuel inlet nut wrench [Re: Mr PotatoHead] #2808244
08/12/20 09:48 PM
08/12/20 09:48 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
I took some old wrenches and ground them down to fit made them narrower and thinner
NS1AAR
Re: holley six pack fuel inlet nut wrench [Re: ns1aar] #2808389
08/13/20 11:33 AM
08/13/20 11:33 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
With the "correct" 1" not worn out wrench and a 1/2" line wrench,I've never had a problem getting a fuel inlet fitting apart and I've been doing sixpack carbs since the early 90's. twocents
Re: holley six pack fuel inlet nut wrench [Re: ns1aar] #2808628
08/13/20 08:29 PM
08/13/20 08:29 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: holley six pack fuel inlet nut wrench [Re: TJP] #2808885
08/14/20 02:39 PM
08/14/20 02:39 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Over the past 40+years of running my six-pack, I've concluded to using specific-only wrenches from my tool box that fit best to r/r the factory fuel line assembly... from the bowls. Once you find the best ones, remember (or mark) them.
