holley six pack fuel inlet nut wrench
#2808020
08/12/20 11:20 AM
08/12/20 11:20 AM
Posts: 574 Just South of The Motor City
limechallenger
Ok , so I got a 340 sixpack in my 70 Challenger T/A. The accelerator pump blew out and I need to replace it! So as I try to get the carbs off I unfortunately kinked the center carb fuel line. the inlet fuel bowl nut turned and not the fuel line nut! I've tried every wrench in my box and cant get anything on it to hold it while I loosen the line nut! Does anyone know if there is a special wrench available to make thin job easier?
p.s. I will be ordering a new set of stainless lines for re installation
70 T/A Challenger
78 Aspen R/T
87 Indy 500 Dakota
Re: holley six pack fuel inlet nut wrench
[Re: limechallenger]
#2808045
08/12/20 11:55 AM
08/12/20 11:55 AM
Posts: 9,471 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Since you have already jacked it, needle nose vise grips tight and whack with small hammer.
If you are using org. lines and want to keep that look Ive a few spare sections.
You may remove the linkage clip and the 4 vac pod screws on the front pod to get at it better, just dont lose the small gasket from the pod to carb.
Id just cut the line out. Remove your front vac pod.
STOP POTATO HATE!
[Re: tman]
#2808111
08/12/20 02:24 PM
08/12/20 02:24 PM
Posts: 3,682 South San Francisco, Ca
70sixpkrt
For me I remove the line from the distribution block and leave it on the carb inlet. When the carb is out, then you can remove the inlet lines if you need to. Just like this.
[Re: 70sixpkrt]
#2808116
08/12/20 02:36 PM
08/12/20 02:36 PM
Posts: 566 WA
tman
WA
For me I remove the line from the distribution block and leave it on the carb inlet. When the carb is out, then you can remove the inlet lines if you need to. Just like this. You got that right!
#2808136
08/12/20 03:36 PM
08/12/20 03:36 PM
Posts: 43,198 Bend,OR USA
Cab_Burge
[Re: 5carguy]
#2808209
08/12/20 07:50 PM
08/12/20 07:50 PM
limechallenger
I kind of think that if you buy stainless lines they are tough to seal.Heck,the mild steel are bad enough. That's a good point, maybe I should consider going back to factory correct!
70 T/A Challenger
78 Aspen R/T
87 Indy 500 Dakota
[Re: Mr PotatoHead]
#2808234
08/12/20 09:15 PM
08/12/20 09:15 PM
limechallenger
Those look like Stainless lines if they are did you have any leakage problems?
70 T/A Challenger
78 Aspen R/T
87 Indy 500 Dakota
#2808241
08/12/20 09:40 PM
08/12/20 09:40 PM
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Ive never had no issues with the SS, just like SS brake lines we all have different methods.
I do use good wrenches, and I will seat them hard one time and back off and re tighten. It helps if you can leave the carbs a hair loose and let the lines find a happy spot then tighten carbs. But again, everyone is different.
I bought several sets of the SS lines off ebay when inline tube dumped there stock for $25 shipped, the flippers bought hundreds of them and now they are hoping people forget as they are creeping the prices back way up.
So if you can shop around, everyone paid the same.
STOP POTATO HATE!
[Re: Mr PotatoHead]
#2808244
08/12/20 09:48 PM
08/12/20 09:48 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
I took some old wrenches and ground them down to fit made them narrower and thinner
NS1AAR
[Re: TJP]
#2808885
08/14/20 02:39 PM
08/14/20 02:39 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Over the past 40+years of running my six-pack, I've concluded to using specific-only wrenches from my tool box that fit best to r/r the factory fuel line assembly... from the bowls. Once you find the best ones, remember (or mark) them.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
