Page 3 of 3 1 2 3
Re: NEW DIRECTION IN THE 318 BUILD!Getting a 360 [Re: erick72] #280842
04/13/09 08:26 AM
04/13/09 08:26 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
any aftermarket cam will have the pushrod oiling lifters except maybe mopar performance ones. everyone else (comp, crane, summit, lunati) lists the same lifters for AMC and chrysler.
w/o decking or new pistons, with the mag heads and stock LA shortblock, if you use the think Mr. gasket/MP head gaskets (.028" thick) and your mag heads are stock 63ccish chambers, you'll be at about 8.6-8.7:1 compression.
decking will most likely be more expensive than the cost of the pistons, but then, you probably would want to actually get the block bored if you're buying new slugs.
I'd be leery of even that much lift on stock mag valve springs. remember, on the magnum engine that will be .470/.470 lift. I'd use the GM 3100 springs/retainers with that cam.
2017 Grand Cherokee Overland
Re: NEW DIRECTION IN THE 318 BUILD!Getting a 360 [Re: erick72] #280843
04/13/09 09:11 AM
04/13/09 09:11 AM
what do you think i would be at compression wise?
when you mock everything up & find your deck height/head cc's this is an easy to use CR calculator. http://kb-silvolite.com/calc.php?
Re: NEW DIRECTION IN THE 318 BUILD!Getting a 360 [Re: patrick] #280844
04/13/09 01:48 PM
04/13/09 01:48 PM
Detroit,Michigan USA!
E
erick72 Offline OP
erick72  Offline OP
E
how mch horse you think i can get?
Re: NEW DIRECTION IN THE 318 BUILD!Getting a 360 [Re: erick72] #280845
04/13/09 01:57 PM
04/13/09 01:57 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
that cam w/1.6 rockers will end up having specs in .050 duration and lift similar to a comp XE262.
dulcich made 335hp/400tq with a stock long block 360 from the early 80's, hooker headers, and a comp XE262.
see article:
http://compcams.com/Community/Articles/Details.asp?ID=-409383413
with the mag heads giving slightly better flow, more velocity, and 3/4 of a point higher compression, I'd probably put the motor in the 350-355HP/410-420tq range as long as the bottom end is in good shape with good ring seal.
Re: NEW DIRECTION IN THE 318 BUILD!Getting a 360 [Re: patrick] #280846
04/13/09 02:36 PM
04/13/09 02:36 PM
E
erick72 Offline OP
erick72  Offline OP
E
see article:
you think my cam the summit k6901 is good enough?like identical to that one in that article you gave me?
Re: NEW DIRECTION IN THE 318 BUILD!Getting a 360 [Re: erick72] #280847
04/13/09 02:47 PM
04/13/09 02:47 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Patrick I had the heads milled here for him .030 but I was getting ready to CC them after that and dropped my beaker(glass).
I just did a tad bit of a bowl clean up and opened the PR pinch a few thou on either side.
I would think he would be OK with the stock springs and that small of a cam becasue the liftes are so much lighter than the stock rollers. Mabey I am wrong
Re: NEW DIRECTION IN THE 318 BUILD!Getting a 360 [Re: HotRodDave] #280848
04/13/09 02:55 PM
04/13/09 02:55 PM
E
erick72 Offline OP
erick72  Offline OP
E
maybe it would be better to explain what i want lol.
i would like that lumpy muscle car tone,enough cam to get 350 hp,but small enough of a cam to accept the magnum valve springs.
does this help at all?from the sound of it the summit k6901 would fit two of the three the one idk bou tis it working with the gm valve springs.
Re: NEW DIRECTION IN THE 318 BUILD!Getting a 360 [Re: erick72] #280849
04/13/09 03:04 PM
04/13/09 03:04 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
comp XE262 is 262/270 adv, 218/224 .050, .462/.470 lift, 110 LSA, 46 degrees overlap.
the summit K6901 (with magnum 1.6 ratio rockers) is 276/286 adv, 218/228 .050 duration, .470/.470 lift, 114 LSA, 53 degrees overlap
since .050 duration is near identical, these cams should have similar RPM ranges. the 114 LSA of the summit cam might sacrafice a little low end/midrange torque and carry the powerband slightly higher. the additional 7 degrees of overlap should make the idle lumpier. similar .050 duration and lift numbers mean they should make similar power, if head flow is similar.
Re: NEW DIRECTION IN THE 318 BUILD!Getting a 360 [Re: patrick] #280850
04/13/09 03:11 PM
04/13/09 03:11 PM
E
erick72 Offline OP
erick72  Offline OP
E
so in ther words the cam is fine then?
thanks patrick in advance for your help.
and you too hotroddave!
Re: NEW DIRECTION IN THE 318 BUILD!Getting a 360 [Re: patrick] #280851
04/13/09 03:24 PM
04/13/09 03:24 PM
E
erick72 Offline OP
erick72  Offline OP
E
see article:
oh yeah idk if you noticed but you know they made 335 horse with a block bored 40 over.
Re: NEW DIRECTION IN THE 318 BUILD!Getting a 360 [Re: erick72] #280852
04/13/09 03:46 PM
04/13/09 03:46 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
the overbore will add 7 cubic inches. it won't really affect power at all, maybe 1-2% at most over a similarly built standard bore engine
condition of the bores (are they round? tapered?), and ring seal quality will have a larger effect on power than .040" more bore will
Re: NEW DIRECTION IN THE 318 BUILD!Getting a 360 [Re: patrick] #280853
04/13/09 11:49 PM
04/13/09 11:49 PM
E
erick72 Offline OP
erick72  Offline OP
E
idk yet.waiting till friday to look.
Page 3 of 3 1 2 3
