Air pan question #280745
04/07/09 07:35 PM
04/07/09 07:35 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Going to make a pan to seal the carb to the hood. How are you attaching your pan to the carb? Also, if the fit is tight between the hood and pan do you need a hold down on the pan? Pics would be great!!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Air pan question [Re: Von] #280746
04/07/09 07:53 PM
04/07/09 07:53 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
1.39 9.85 - 137 mph
Re: Air pan question [Re: Ari440] #280747
04/08/09 10:17 AM
04/08/09 10:17 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Thanks! I had seen your pic before and knew you used a stop sign. I have a No Dumping sign that has been sitting in my office for at least 9 years.... So you know where it is going.
Do you think the strap across the top messes with the airflow at all?
Re: Air pan question [Re: Von] #280748
04/08/09 11:09 AM
04/08/09 11:09 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
You could always use some solid rod stock.
Re: Air pan question [Re: Von] #280749
04/08/09 11:28 AM
04/08/09 11:28 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
I'm going to be building a plate for the 63 and plan on attaching it to the fiberglass hood.
I'll take images as I build it. Should be pretty simple
The material will be much lighter that what a sign is made of.
Re: Air pan question [Re: Rodney] #280750
04/08/09 12:59 PM
04/08/09 12:59 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
heres an old pic :
you can see the strap in the scoop it dont slow the air down
1.39 9.85 - 137 mph
Re: Air pan question [Re: Ari440] #280751
04/08/09 01:24 PM
04/08/09 01:24 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I use the Moroso air pan and never had anything but the hood pushing down on foam holding it. I did notice that from time to time it would rotate a little so I put a strap on it that slids down over the bowl vent tube to keep it straight.
Re: Air pan question [Re: WILD BILL] #280752
04/08/09 05:48 PM
04/08/09 05:48 PM
KY
juicedcuda Offline
juicedcuda  Offline
KY
Do you have any pics or part #'s on this moroso airpan?
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: Air pan question [Re: juicedcuda] #280753
04/08/09 06:44 PM
04/08/09 06:44 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I can get you one but I don't get home till around 8:30pm.
Don't let me forget
Re: Air pan question [Re: Ari440] #280754
04/08/09 07:07 PM
04/08/09 07:07 PM
FL
74-440Charger Offline
FL
Any concern over running without the air filter? Would one of the better filters (K&N) be a restriction?
Re: Air pan question [Re: 74-440Charger] #280755
04/08/09 08:57 PM
04/08/09 08:57 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: Air pan question [Re: Von] #280756
04/10/09 07:27 PM
04/10/09 07:27 PM
Louisville, KY
Allan_G Offline
Allan_G  Offline
Louisville, KY
I use an air cleaner to hold mine on. The foam strips are the ones used to seal window A/C units to window openings. They've been trimmed to the contour of the hood and then glued to the air pan (.040 aluminum sheet I think).
(FKA Racer Al back in 2000...)
Re: Air pan question [Re: Allan_G] #280757
04/10/09 07:29 PM
04/10/09 07:29 PM
Louisville, KY
Allan_G Offline
Allan_G  Offline
Louisville, KY
The air cleaner base is riveted to the pan.
Re: Air pan question [Re: Allan_G] #280758
04/10/09 07:31 PM
04/10/09 07:31 PM
Louisville, KY
Allan_G Offline
Allan_G  Offline
Louisville, KY
I use air cleaner spacers glued together to get the right height for the assembly. As you can see, the upper one has been shortened.
Re: Air pan question [Re: Allan_G] #280759
04/10/09 07:38 PM
04/10/09 07:38 PM
Louisville, KY
Allan_G Offline
Allan_G  Offline
Louisville, KY
Here's a pic through the scoop opening. For the rare occasion when I have driven it in the rain, I have a spare air cleaner base so that I can plug the scoop and remove the air pan. The filter is a K&N 14x3, and there was no performance change when tested with/without the filter (345ci, 6.90s/11.0s). When I build a stroker, I will use the filter top and a taller element if necessary to keep the restriction down.
Re: Air pan question [Re: Von] #280760
04/22/09 05:54 PM
04/22/09 05:54 PM
Wi.
65_gt_rag_402 Offline
Wi.
just fabbed up an air pan for my dart . Here is a pic
14" x 3" air cleaner
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!! 11.0's on pump gas .
