Re: Alcohol Carb?
[Re: DavidDean]
#2808230
08/12/20 09:05 PM
08/12/20 09:05 PM
Posts: 38 Ohio
Oldbracketracer
Ohio
Thanks for the replies. APD was already on the list to consider based on what some of my friends have seen.These things are spendy enough that you want to get it right and you guys have been helpful.
Re: Alcohol Carb?
[Re: Cab_Burge]
#2808453
08/13/20 01:45 PM
08/13/20 01:45 PM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
Second vote for Quickfuel. I removed a Rupert 1050 Dominator from the Daytona and bolted on a box stock Quickfuel 950 4150 carb. We wanted to slow the car down a little since it was running low 8.50's and the chassis cert is only 8.50 The Quickfuel 4150 ran the exact same ET and MPH as the Rupert Dominator! I was surprised to say the least. This is on a 540 with 345 440-1 heads We since have switched over to a Quickfuel E85 950 4150 carb. Plugged the PV and square jetted to 98 and it works beautiful! Slowed the car a tenth which is what I was looking for.
Re: Alcohol Carb?
[Re: bobs69]
#2808860
08/14/20 01:39 PM
08/14/20 01:39 PM
cl440
S.E. Michigan
Good thing is the tuning window on alcohol is very broad. You should have better luck finding a good working OTB alcohol carb vs a gas or E85 carb
