What do you call Smaller Size Washers?
#2807216
08/10/20 11:24 AM
08/10/20 11:24 AM
Posts: 28,612 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
I need to order some smaller diameter flat washers as ARP sends with bolt kits. they are the same size diameter wise as "Split Lock Washers" but are flat. Is there a chart someplace that shows the OD of various sizes like 5/16-3/8-7/16-3/8" Outside Diameter?
Re: What do you call Smaller Size Washers?
[Re: burdar]
#2807274
08/10/20 01:31 PM
08/10/20 01:31 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
SAE washers are smaller and fit the bolts much tighter than USS washers. Then you get into specialty washers.
[Re: 340SIX]
#2807280
08/10/20 01:41 PM
08/10/20 01:41 PM
Posts: 284 Bennett, Colorado
Charger69RT8
Bennett, Colorado
Not a chart, but good sources for seeing all the sizes McMasterFastenal
2012 Challenger SRT 2012 Charger SXT AWD 69 Charger R/T 78 Chrysler New Yorker 440CI 89 Dodge Daytona ES 2.5L Turbo 99 Ram 2500 4X4 5.9L6
[Re: Cab_Burge]
#2807353
08/10/20 04:11 PM
08/10/20 04:11 PM
340SIX
AN washers are thinner in diameter than regular washers ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) I use them under any bolt that is going against aluminum so the bolt head doesn't dig into the aluminum Thanks to all the replys That is what I ordered as That is 100% what I wanted them for and did not want them to stick out past the heads of the bolts. And ARP charges a ton for that size and shipping if that is all a person orders
[Re: AndyF]
#2807401
08/10/20 06:49 PM
08/10/20 06:49 PM
340SIX
Andy thanks for that link I had not looked at the site in years they sure have added a whole lot of items to the catalog. They really stepped up what they make. I have been sanding and polishing regular Stainless Bolts / Nuts and wanted some smaller washers as all we have here locally is the large standard size.
