What do you call Smaller Size Washers? #2807216
08/10/20 11:24 AM
08/10/20 11:24 AM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
I need to order some smaller diameter flat washers as ARP sends with bolt kits. they are the same size diameter wise as "Split Lock Washers" but are flat.
Is there a chart someplace that shows the OD of various sizes like 5/16-3/8-7/16-3/8" Outside Diameter?
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: What do you call Smaller Size Washers? [Re: 340SIX] #2807246
08/10/20 12:22 PM
08/10/20 12:22 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
AN washers are thinner in diameter than regular washers
Re: What do you call Smaller Size Washers? [Re: 340SIX] #2807247
08/10/20 12:23 PM
08/10/20 12:23 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Ride eternal, shiny and chrome
Re: What do you call Smaller Size Washers? [Re: Sniper] #2807259
08/10/20 12:56 PM
08/10/20 12:56 PM
iagree scope
I use them under any bolt that is going against aluminum so the bolt head doesn't dig into the aluminum twocents
Re: What do you call Smaller Size Washers? [Re: Cab_Burge] #2807268
08/10/20 01:13 PM
08/10/20 01:13 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I found a hardware store once that carried 1/4" washers with the outside diameter of a #10. Those work really nice. I hate having to drill out a #10 when a standard 1/4" washer is too big.
Re: What do you call Smaller Size Washers? [Re: burdar] #2807274
08/10/20 01:31 PM
08/10/20 01:31 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
SAE washers are smaller and fit the bolts much tighter than USS washers. Then you get into specialty washers.
Re: What do you call Smaller Size Washers? [Re: 340SIX] #2807280
08/10/20 01:41 PM
08/10/20 01:41 PM
Bennett, Colorado
Charger69RT8 Offline
Bennett, Colorado
Not a chart, but good sources for seeing all the sizes
McMaster
Fastenal
2012 Challenger SRT
2012 Charger SXT AWD
69 Charger R/T
78 Chrysler New Yorker 440CI
89 Dodge Daytona ES 2.5L Turbo
99 Ram 2500 4X4 5.9L6
Re: What do you call Smaller Size Washers? [Re: Sniper] #2807310
08/10/20 02:29 PM
08/10/20 02:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree AN960 flat washers come in carbon steel, stainless steel and aluminum...thick and thin.
https://www.pegasusautoracing.com/productselection.asp?Product=AN960
Re: What do you call Smaller Size Washers? [Re: Cab_Burge] #2807353
08/10/20 04:11 PM
08/10/20 04:11 PM
340SIX Offline OP
340SIX  Offline OP
iagree scope
Thanks to all the replys That is what I ordered as That is 100% what I wanted them for and did not want them to stick out past the heads of the bolts.
And ARP charges a ton for that size and shipping if that is all a person orders
Re: What do you call Smaller Size Washers? [Re: 340SIX] #2807397
08/10/20 06:05 PM
08/10/20 06:05 PM
AndyF Offline
AndyF  Offline
ARP makes a lot of custom washers that you might not be able to find anywhere else. I use a lot of ARP stuff but I also buy a lot from Specialty.
https://www.specialty-fasteners.com/Default.asp
Re: What do you call Smaller Size Washers? [Re: AndyF] #2807401
08/10/20 06:49 PM
08/10/20 06:49 PM
340SIX Offline OP
340SIX  Offline OP
Andy thanks for that link I had not looked at the site in years they sure have added a whole lot of items to the catalog. They really stepped up what they make.
I have been sanding and polishing regular Stainless Bolts / Nuts and wanted some smaller washers as all we have here locally is the large standard size.
Re: What do you call Smaller Size Washers? [Re: 340SIX] #2807457
08/10/20 09:02 PM
08/10/20 09:02 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Washettes?
