904 Clutch Plates? #28042
06/02/06 12:25 PM
06/02/06 12:25 PM
Tucson, Arizona
clonestocker Offline OP
Tucson, Arizona
Is there a difference in clutch material in the two different clutch packs? Taking my trans apart I have two different types of clutches? The guy at the parts store said it doesn't make a difference. I had Borg Warner in the high gear drum, and these black plates in the direct drum(?). These black plates are falling apart. Is it a problem to use the Borg Warner plates in both clutch packs? thx matt s
[img] [/img]
Re: 904 Clutch Plates? [Re: clonestocker] #28043
06/02/06 12:49 PM
06/02/06 12:49 PM
Mo.
1100HPSmallBlock Offline
Mo.
The forward (rear clutches) are thinner than the direct(front). If you swap them you have clearance issues.
Re: 904 Clutch Plates? [Re: clonestocker] #28044
06/02/06 12:52 PM
06/02/06 12:52 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I don't believe it make's any diff on the material, but the thing that I have found is the grooves in the facing, one will have grooves straight across the face and the other will look like a waffle, the only other thing to watch is the thickness of the fiber plate, when I got my master overhaul kit from Mancini the fiber disc's were all the same blue plate material.
Re: 904 Clutch Plates? [Re: 1100HPSmallBlock] #28045
06/02/06 12:59 PM
06/02/06 12:59 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
that being the case then after reviewing a NAPA kit that I have, then the direct clutches are the waffle ones and yes there is a thickness difference, and the material appears to be the same in that kit also.
Re: 904 Clutch Plates? [Re: dartman366] #28046
06/02/06 01:20 PM
06/02/06 01:20 PM
Tucson, Arizona
Tucson, Arizona
The waffle plates are .082 thick. The other plates are .062 thick. Using the .062 plates allows you to put 5 plates in the front drum. I was told to do this by Dave Smith @ ProTrans. Need more input. thx matt s
[img] [/img]
Re: 904 Clutch Plates? [Re: clonestocker] #28047
06/02/06 04:47 PM
06/02/06 04:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
One reason for the difference in clutch material is because the rear clutch normally engages at idle with the car at a standstill and remains engaged for all forward gears, the front clutch engages under power.
Re: 904 Clutch Plates? [Re: John_Kunkel] #28048
06/02/06 06:03 PM
06/02/06 06:03 PM
Tucson, Arizona
Tucson, Arizona
John, Do you think it matters if the front drum clutches are in the rear drum also? thx matt s
[img] [/img]
Re: 904 Clutch Plates? [Re: clonestocker] #28049
06/02/06 08:04 PM
06/02/06 08:04 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Oh I'm so glad I read this. . . do not put 5 clutch plates in the high gear drum without being very careful. Yes it works but there is a potential for a big problem there. The problem is that the input shaft/rear clutch drum splines do not engage the bottom (5th) clutch. I had one that I went round and round on trying to figure out why it would only flare the 2-3 shift at high rpm. It's because the bottom clutch wasn't engaged which caused it to keep the whole clutch pack from clamping. Now there are several different height rear drum splines, so if you have the right spline height on the drum you can do it, but I have not had good sucess. Search for my other post "everything you never wanted to know about a 904" There is a lot of detail about what I went through. . . Just my 2 cents, and maybe you already have the right rear drum spline, but just be careful!!
Re: 904 Clutch Plates? [Re: dizuster] #28050
06/02/06 08:07 PM
06/02/06 08:07 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
By the way, I got my original brilliant idea from having a protrans apart from a pro nostalgia car. It seemed like a great idea, but they must make sure they use the correct drum.
Also supposidly because the direct drum is a dynamic apply, the waffle grooves cut in the clutches allow it to relieve the fluid between the plates. That's why the direct clutches are waffled and the rear clutches are not. The rear clutch is on in all forward gears so it never really gets a dynamic apply (unless you neutral slam it of course lol . . )
Re: 904 Clutch Plates? [Re: dizuster] #28051
06/02/06 10:13 PM
06/02/06 10:13 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
With the right parts as described above I used 5 clutches (thin) in the front drum with good sucess .But as stated above and in the 904 post you must have the right parts.I'm building a spare 904 and I've been back to the trans supply shops a number of times looking for the right parts LOL!
Re: 904 Clutch Plates? [Re: clonestocker] #28052
06/03/06 05:11 PM
06/03/06 05:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The front discs usually have a waffle pattern to allow fluid to be squeezed from between the discs during engagement, the channels in the waffle pattern reduce the actual surface contact area but this is a necessary tradeoff for good application.
The rear clutches aren't applied under power and therefore don't need the waffle pattern so the reduction in surface area has no tradeoff benefit as it does in the front. A flat pattern with occasional diagonal slots and metallic lining is the traditional rear disc and offers the maximum surface area.
My , I'm sure some others will disagree.
Re: 904 Clutch Plates? [Re: John_Kunkel] #28053
06/03/06 11:14 PM
06/03/06 11:14 PM
NC
440Jim Offline
440Jim  Offline
NC
I agree with John 100%. (or more)
And in the 904, it is more important than the 727 since everything is smaller.
Re: 904 Clutch Plates? [Re: John_Kunkel] #28054
06/04/06 12:09 AM
06/04/06 12:09 AM
Tucson, Arizona
Tucson, Arizona
Thanks John. matt
[img] [/img]
Re: 904 Clutch Plates? [Re: clonestocker] #28055
06/04/06 10:47 AM
06/04/06 10:47 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Note: text from this thread has been added to "everything you never wanted to know about 904s" in an attempt to keep all the info together.
Rich H.
Esse Quam Videri
