904 Clutch Plates?
#28042
06/02/06 12:25 PM
06/02/06 12:25 PM
Posts: 2,155 Tucson, Arizona
clonestocker
Tucson, Arizona
Is there a difference in clutch material in the two different clutch packs? Taking my trans apart I have two different types of clutches? The guy at the parts store said it doesn't make a difference. I had Borg Warner in the high gear drum, and these black plates in the direct drum(?). These black plates are falling apart. Is it a problem to use the Borg Warner plates in both clutch packs? thx matt s
[img] [/img]
Re: 904 Clutch Plates?
[Re: clonestocker]
#28044
06/02/06 12:52 PM
06/02/06 12:52 PM
dartman366
Mt. Vernon, Ohio
I don't believe it make's any diff on the material, but the thing that I have found is the grooves in the facing, one will have grooves straight across the face and the other will look like a waffle, the only other thing to watch is the thickness of the fiber plate, when I got my master overhaul kit from Mancini the fiber disc's were all the same blue plate material.
[Re: dartman366]
#28046
06/02/06 01:20 PM
06/02/06 01:20 PM
clonestocker
Tucson, Arizona
The waffle plates are .082 thick. The other plates are .062 thick. Using the .062 plates allows you to put 5 plates in the front drum. I was told to do this by Dave Smith @ ProTrans. Need more input. thx matt s
[img] [/img]
[Re: clonestocker]
#28047
06/02/06 04:47 PM
06/02/06 04:47 PM
Posts: 25,802 Rio Linda, CA
John_Kunkel
Rio Linda, CA
One reason for the difference in clutch material is because the rear clutch normally engages at idle with the car at a standstill and remains engaged for all forward gears, the front clutch engages under power.
[Re: John_Kunkel]
#28048
06/02/06 06:03 PM
06/02/06 06:03 PM
clonestocker
Tucson, Arizona
John, Do you think it matters if the front drum clutches are in the rear drum also? thx matt s
[img] [/img]
[Re: clonestocker]
#28055
06/04/06 10:47 AM
06/04/06 10:47 AM
Posts: 17,845 S.E. Michigan
ZIPPY
S.E. Michigan
Note: text from this thread has been added to "everything you never wanted to know about 904s" in an attempt to keep all the info together.
Rich H.
Esse Quam Videri
