Magnum 500 wheels #280476
04/07/09 03:37 PM
04/07/09 03:37 PM
san diego,ca
rtrag Offline OP
rtrag  Offline OP
san diego,ca
I bought a set of Magnum 500's for my Challenger, and when we tried to put them on we found that the bolt pattern was correct but the wheel would'nt fit over the hub. Any ideas?
Re: Magnum 500 wheels [Re: rtrag] #280477
04/07/09 03:51 PM
04/07/09 03:51 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
They are Ford wheels. The wheel centers are slightly smaller on the Ford wheels, they probably fit fine on the back?
Sheldon
Re: Magnum 500 wheels [Re: RUNCHARGER] #280478
04/07/09 06:00 PM
04/07/09 06:00 PM
san diego,ca
rtrag Offline OP
rtrag  Offline OP
san diego,ca
No. The guy at the tire shop said they did'nt fit on the rear either. Thanks
Re: Magnum 500 wheels [Re: rtrag] #280479
04/07/09 06:49 PM
04/07/09 06:49 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
the hub meaning the center is to small right?
Re: Magnum 500 wheels [Re: AARCONV] #280480
04/07/09 06:53 PM
04/07/09 06:53 PM
san diego,ca
rtrag Offline OP
rtrag  Offline OP
san diego,ca
Yes. He said the center bore was a little too small.
Re: Magnum 500 wheels [Re: rtrag] #280481
04/07/09 06:59 PM
04/07/09 06:59 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Are you running the stock sized front rotors?
I tried putting 500's on a 76 Charger and found the center hub was too big to fit down inside the wheels. The Charger had factory 15" wheels. Maybe there was a difference in the hub diameter between 14" and 15" wheels.
Re: Magnum 500 wheels [Re: burdar] #280482
04/07/09 07:02 PM
04/07/09 07:02 PM
san diego,ca
rtrag Offline OP
rtrag  Offline OP
san diego,ca
That could be .I put disc brakes on the front, so there is a chance that the hub is different, but the wheels should still fit on the rear.
Re: Magnum 500 wheels [Re: rtrag] #280483
04/07/09 08:07 PM
04/07/09 08:07 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
The ford ones will not fit front or rear from memory. They used a smaller diameter front hub and also a smaller diameter register on the axle flange for the brake drum. Only solution I can think of to keep using the wheels you just got would be to run a small wheel spacer perhaps and see if that will let the wheel clear (and not rub on the car)
Re: Magnum 500 wheels [Re: OzHemi] #280484
04/07/09 08:22 PM
04/07/09 08:22 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
This wont help you but thought I would mention that I purchased a set of chrome rallys for a small bolt pattern 67 Barrcauda from Summit Racing, the wheels were made by Wheel Vintiques. I had the same issue, They would not fit over the front hub (disc brake car) I sent them back to Summit for a refund and bought a different brand. Had no issues. Seems some people have issues with Wheel Vintiques quality.Wonder if thats what you have here?
Re: Magnum 500 wheels [Re: Suregrip391] #280485
04/07/09 08:41 PM
04/07/09 08:41 PM
Detroit area
6PAX Online content
6PAX  Online Content
Detroit area
I have Magnums from a 71 Mach I on my 71 Challenger and they fit fine on the rear. They also fit fine on the front but I have drum brakes up front.
Re: Magnum 500 wheels [Re: 6PAX] #280486
04/07/09 08:44 PM
04/07/09 08:44 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I tried to use Ford ones on a Mopar before and they didn't clear from memory (been some years now..)
Re: Magnum 500 wheels [Re: OzHemi] #280487
04/07/09 09:01 PM
04/07/09 09:01 PM
Detroit area
6PAX Online content
6PAX  Online Content
Detroit area
I bought the wheels from a friend who also had them on a 66 Satellite and if I'm not mistaken it has disk brakes on it.
Re: Magnum 500 wheels [Re: 6PAX] #280488
04/07/09 09:04 PM
04/07/09 09:04 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Were they repo's or original ones? The ones I was trying to use were factory ones...
If they were stock, then..
Re: Magnum 500 wheels [Re: OzHemi] #280489
04/07/09 09:14 PM
04/07/09 09:14 PM
Detroit area
6PAX Online content
6PAX  Online Content
Detroit area
They are originals from a 71 Mach I.
Re: Magnum 500 wheels [Re: 6PAX] #280490
04/08/09 07:49 AM
04/08/09 07:49 AM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
I bought a used set of 15X7 ford magnums back in the 80s. Had to enlarge the center hole so the mopar center cap retainer would fit but otherwise they worked perfect.
Re: Magnum 500 wheels [Re: 6PAX] #280491
04/08/09 12:39 PM
04/08/09 12:39 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
The are originals from a 71 Mach I.
Don't know why they worked then..but know the Ford ones I tried wouldn't fit...
Re: Magnum 500 wheels [Re: OzHemi] #280492
04/08/09 09:04 PM
04/08/09 09:04 PM
This subject is very interesting. Two weeks ago I just put on orginal 14"Ford magnum 500 wheels on my 72 Road Runner with disk brakes and didn't have any trouble.
Thanks Moparts
Re: Magnum 500 wheels #280493
04/10/09 04:34 PM
04/10/09 04:34 PM
Went to my 72 Road Runner that I said I had Ford magnum 500 wheels on . I reached in thru the slots to see if I could feel if the back of the wheel was against the brake caliber and the wheel was tight against.
Thanks Moparts
Re: Magnum 500 wheels #280494
04/10/09 07:57 PM
04/10/09 07:57 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Here are the problems I have run into. Ford rims won't work on 73 and up big bearing discs and early Mopar magnums won't clear the floating caliper disc set up's with out a spacer. Never had any problems with any fitting on the rear.
Re: Magnum 500 wheels [Re: rrunner] #280495
04/11/09 12:00 AM
04/11/09 12:00 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
On several (at least 3) occasions I've put repro Ford 14x7 Magnums on drum-brake '68-'69 B-bodies with no problems except the front weights had to be stick-ons and not clipped to the inner lip; clip-ons hit the lip of the upper control arm slightly. (In each case I wanted the weights on the inside for a cleaner look.) No problems at all on the rear. The standard (meaning using caps or covers) stamped Ford wheels do have smaller center holes. None of mine have (or had) disk brakes, so I don't know about any differences there.
