using dual line locks #2802140
07/28/20 02:06 PM
07/28/20 02:06 PM
my own world
theraif Offline OP
theraif  Offline OP
my own world
grin or your the brother that won rock,paper.scissors and get to drive
Re: using dual line locks [Re: theraif] #2802440
07/29/20 10:53 AM
07/29/20 10:53 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
LOL...
They are usually not legal, especially the version pictured!
Re: using dual line locks [Re: 340Cuda] #2802471
07/29/20 12:11 PM
07/29/20 12:11 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Although I agree with you...does anyone know why Dual LL are not legal?...and not the ones that hold your bumper.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: using dual line locks [Re: theraif] #2802473
07/29/20 12:12 PM
07/29/20 12:12 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
That's awesome.
The pavement in front of my parents house looked like the staging lanes at Northstar dragways from us and our friends.
If your car couldn't do a proper burn out , there was usually a few volunteers who would hoist the back of the car up high enough to get them spinning.
Then , we discovered alternative uses for drain oil.
A six cylinder '70 Mustang looked like the Blue Max heating the hides coming out of that stuff. LOL
Re: using dual line locks [Re: W.I.N. Racing] #2802489
07/29/20 12:38 PM
07/29/20 12:38 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
My understanding is that they are not legal in Sportsman/Footbrake classes because they are a "poor man's" transbrake, and can also be used with a hidden box....
Re: using dual line locks [Re: slantzilla] #2802515
07/29/20 01:17 PM
07/29/20 01:17 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
25 years ago when a guy in the shop said his car would not spin the tires, a local said all you need is HOLESHOT GRAVEL!
Re: using dual line locks [Re: dodger mope] #2802579
07/29/20 04:00 PM
07/29/20 04:00 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I tried it long ago. Released way to slow, worthless.
Doug
Re: using dual line locks [Re: dvw] #2802617
07/29/20 06:09 PM
07/29/20 06:09 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Used it from 1985 until 1995. Worked great with a delay box, 2-step, soft touch. Weak link was, and will always be, the driver, me.
Re: using dual line locks [Re: Leigh] #2802783
07/30/20 09:46 AM
07/30/20 09:46 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
I used the two line locks, for the front I had a rectifier out of an alternator so as not to energize the back brakes. Worked great with two step and delay box at 3000. Later on when trans brakes came out I switched. Also tried the throttle air bottle gizmo, it let the pedal go to floor then delay box on release activated the air plunger to snap the throttle on. I liked that system better because the squirters were not used up.
Re: using dual line locks [Re: slantzilla] #2802786
07/30/20 09:58 AM
07/30/20 09:58 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have often wondered myself and this is about as close as I can get to a reason.
Re: using dual line locks [Re: cudaman1969] #2802805
07/30/20 10:51 AM
07/30/20 10:51 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I built a system like you describe, did not use a rectifier, or a delay box. Just locked front and back brakes, my Dodge had drums on all wheels then. Stage the car, hit the button lock the wheels, air cylinder expanded and held at launch RPM, released the button, line locks released, air cylinder closed and launched the car. You could dial it into the tree by changing the air pressure coming out of the bottle with a regulator. Worked very well.
Re: using dual line locks [Re: slantzilla] #2802872
07/30/20 12:19 PM
07/30/20 12:19 PM
Byron, NY
Byron, NY
Thank you
'60 Willys CJ5
Re: using dual line locks [Re: W.I.N. Racing] #2802895
07/30/20 01:36 PM
07/30/20 01:36 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Some classes prohibit rear wheel Line Locs - Stock & Super Stock for 2. General regs says - application and release must be a direct action by the driver. No electronics, hydraulics, pneumatics, or other device may affect brake operation. Line-loc can be used to hold the car on the line, but It has to be applied and released with a driver operated switch. Can't be tied into a clutch switch, delay box, etc.
Re: using dual line locks [Re: jwb123] #2802940
07/30/20 02:50 PM
07/30/20 02:50 PM
fredericksburg,va
fredericksburg,va
I should of said I separated them just to do a burn out, one button for front (on shifter) the other for both on steering wheel leaving on top light, then adjusted in the box for reaction times. I also had my practice box tied into it all so I could sit in staging lane popping the button about 20 times to get in a groove.
