Re: using dual line locks
[Re: 340Cuda]
#2802471
07/29/20 12:11 PM
07/29/20 12:11 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
Although I agree with you...does anyone know why Dual LL are not legal?...and not the ones that hold your bumper.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2802489
07/29/20 12:38 PM
07/29/20 12:38 PM
Posts: 20,185 Park Forest, IL
slantzilla
Park Forest, IL
Although I agree with you...does anyone know why Dual LL are not legal?...and not the ones that hold your bumper. My understanding is that they are not legal in Sportsman/Footbrake classes because they are a "poor man's" transbrake, and can also be used with a hidden box....
[Re: slantzilla]
#2802786
07/30/20 09:58 AM
07/30/20 09:58 AM
Posts: 3,521 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Although I agree with you...does anyone know why Dual LL are not legal?...and not the ones that hold your bumper. My understanding is that they are not legal in Sportsman/Footbrake classes because they are a "poor man's" transbrake, and can also be used with a hidden box.... I have often wondered myself and this is about as close as I can get to a reason.
[Re: cudaman1969]
#2802805
07/30/20 10:51 AM
07/30/20 10:51 AM
Posts: 879 Missouri
jwb123
Missouri
I used the two line locks, for the front I had a rectifier out of an alternator so as not to energize the back brakes. Worked great with two step and delay box at 3000. Later on when trans brakes came out I switched. Also tried the throttle air bottle gizmo, it let the pedal go to floor then delay box on release activated the air plunger to snap the throttle on. I liked that system better because the squirters were not used up. I built a system like you describe, did not use a rectifier, or a delay box. Just locked front and back brakes, my Dodge had drums on all wheels then. Stage the car, hit the button lock the wheels, air cylinder expanded and held at launch RPM, released the button, line locks released, air cylinder closed and launched the car. You could dial it into the tree by changing the air pressure coming out of the bottle with a regulator. Worked very well.
[Re: slantzilla]
#2802872
07/30/20 12:19 PM
07/30/20 12:19 PM
W.I.N. Racing
Byron, NY
Although I agree with you...does anyone know why Dual LL are not legal?...and not the ones that hold your bumper. My understanding is that they are not legal in Sportsman/Footbrake classes because they are a "poor man's" transbrake, and can also be used with a hidden box.... Thank you
[Re: W.I.N. Racing]
#2802895
07/30/20 01:36 PM
07/30/20 01:36 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Some classes prohibit rear wheel Line Locs - Stock & Super Stock for 2. General regs says - application and release must be a direct action by the driver. No electronics, hydraulics, pneumatics, or other device may affect brake operation. Line-loc can be used to hold the car on the line, but It has to be applied and released with a driver operated switch. Can't be tied into a clutch switch, delay box, etc.
[Re: jwb123]
#2802940
07/30/20 02:50 PM
07/30/20 02:50 PM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
I used the two line locks, for the front I had a rectifier out of an alternator so as not to energize the back brakes. Worked great with two step and delay box at 3000. Later on when trans brakes came out I switched. Also tried the throttle air bottle gizmo, it let the pedal go to floor then delay box on release activated the air plunger to snap the throttle on. I liked that system better because the squirters were not used up. I built a system like you describe, did not use a rectifier, or a delay box. Just locked front and back brakes, my Dodge had drums on all wheels then. Stage the car, hit the button lock the wheels, air cylinder expanded and held at launch RPM, released the button, line locks released, air cylinder closed and launched the car. You could dial it into the tree by changing the air pressure coming out of the bottle with a regulator. Worked very well. I should of said I separated them just to do a burn out, one button for front (on shifter) the other for both on steering wheel leaving on top light, then adjusted in the box for reaction times. I also had my practice box tied into it all so I could sit in staging lane popping the button about 20 times to get in a groove.
