NE1 every try a "hidden" antenna? #280132
04/07/09 12:10 AM
04/07/09 12:10 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I'm thinking of going with a radio delete plate and a hidden stereo in my car, and I was just wondering if any of you have tried any of the "hidden" antennas that are on the market. I'm thinking of putting it under the cardboard of the rear package tray in one of the recesses.
Thanks for any info!
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: NE1 every try a "hidden" antenna? [Re: MadMatt] #280133
04/07/09 12:22 AM
04/07/09 12:22 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I haven't tried one YET, but my application is probably the best and that's a convertible. I plan to mount it below the well a couple of inches above the high part of the trunk floor. I need to order one soon.
Re: NE1 every try a "hidden" antenna? [Re: Jim_Lusk] #280134
04/07/09 09:01 AM
04/07/09 09:01 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
I used a tape on one a while back, You just stick it to the windshield, wrap it around the perimeter of the windshield it has a small wire in the clear tape. Kinda like one wire of a rear defroster. It worked pretty good and nearly invivible.
Re: NE1 every try a "hidden" antenna? [Re: MadMatt] #280135
04/07/09 09:42 AM
04/07/09 09:42 AM
Edmonton , Alberta , Canada
stwheels Offline
stwheels  Offline
Yep, I used a length of foam pipe insulation. I inserted the original fender mounted antenna inside it, taped it in place and then carefully slid the whole thing up under the dash where I used more duct tape to hold it in place. It's been there for about 10 years now. The reception is great and distance wise it seems to get clear reception the same as if it was mounted externally.
Of course I had to fill the hole on the fender with something. This was my solution ... LOL.
Doug Lepak
Re: NE1 every try a "hidden" antenna? [Re: stwheels] #280136
04/07/09 10:55 AM
04/07/09 10:55 AM
USA
b54406barrel Offline
USA
I did a stereo install in the mid-70's on what I remember being a Dodge colt. When I was plugging in the antenna cable, I noticed it didn't have one on the car & there were no wires in the windshield, either. Finally traced the antenna wire & it was hooked to the trunk lid, which was isolated from the rest of the car by rubber/nylon bushings, including the latch. It worked great but I can't remember if it was factory or not. I did the same thing on a couple of other cars I built, shielded wire to trunk lid, shield wire to body, with good results.
Re: NE1 every try a "hidden" antenna? [Re: b54406barrel] #280137
04/07/09 11:16 AM
04/07/09 11:16 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
I have mine mounted under the lip of the dash frame and grounded the base to the dash. Works pretty good and out of sight. A little fading pending direction.
Re: NE1 every try a "hidden" antenna? [Re: Pntastar69] #280138
04/07/09 11:25 AM
04/07/09 11:25 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
They have ones that you can put anywhere. I used one a couple years ago and it worked fine. It was up under the dash, abov the glove box. From Crutchfield IIRC.
Re: NE1 every try a "hidden" antenna? [Re: moper] #280139
04/07/09 11:52 AM
04/07/09 11:52 AM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Got a powered one just under the top of the back seat. Mounted it just about dead center between the "j" hooks the seat back goes on and grounded it right there. Then I went to electronics store got an antenea extention and ran it and the power wire together to the radio. I can't remember the name but I have the package still at home.
Re: NE1 every try a "hidden" antenna? [Re: MadMatt] #280140
04/07/09 02:54 PM
04/07/09 02:54 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Thanks to all for the info. Sounds like there are several viable alternatives. I'm going to give it a shot!!
Re: NE1 every try a "hidden" antenna? [Re: MadMatt] #280141
04/07/09 03:15 PM
04/07/09 03:15 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Matt -
Dunno if you remember Bill's old ranger pickup, but we mounted an antenna (the usual generic extending fender type) inboard of the rt rocker panel. Worked pretty well.
I like the trunklid idea, though, that's trick.
Re: NE1 every try a "hidden" antenna? [Re: MadMatt] #280142
04/07/09 04:20 PM
04/07/09 04:20 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
I shaved my antenna. This is what I used. Mounted it in the trunk, requires no power - actually works. Used the TT2C and painted it black.
http://www.ecshylites.citymax.com/page/page/761353.htm
Re: NE1 every try a "hidden" antenna? [Re: 70Duster440] #280143
04/07/09 04:29 PM
04/07/09 04:29 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
My cars' antena runs up under the windshield. On the glass like the defrosters' painted lines. Works fine, except you can barely make out the oldies it pumps out.
[image][/image]
Can't figure it out. One has to work.
Re: NE1 every try a "hidden" antenna? [Re: 70Duster440] #280144
04/07/09 04:38 PM
04/07/09 04:38 PM
Berwyn, IL
Berwyn, IL
if this really works it looks like a great solution
Re: NE1 every try a "hidden" antenna? [Re: topside] #280145
04/08/09 12:45 PM
04/08/09 12:45 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Matt -
Steve - Can't say I remember the truck, but I'm getting the idea that this won't be too tough to work out. Now, do you happen to have one of those nifty Mopar antenna delete plugs laying around for your 'ol pal?
Re: NE1 every try a "hidden" antenna? [Re: MadMatt] #280146
04/08/09 01:13 PM
04/08/09 01:13 PM
A collage of whims
A collage of whims
Yeah, the Ranger dates back to the good old days, '85 or so.
You might remember that most of my stuff never had a radio, so sorry, no plugs. Gotta be some available here. I like the 8-ball idea posted previously!
Re: NE1 every try a "hidden" antenna? [Re: topside] #280147
04/08/09 04:21 PM
04/08/09 04:21 PM
stwheels Offline
stwheels  Offline
Thanks Steve, here's another shot. All you have to do is hit every garage sale for a summer or two and you'll eventually find one ... LOL.
Don't worry if you find a ball that's all scratched up. Just wet sand it with 2000 grit and then polish with compound till it looks like new.
Doug Lepak
Re: NE1 every try a "hidden" antenna? [Re: MadMatt] #280148
04/08/09 05:12 PM
04/08/09 05:12 PM
Indiana
P
Pentastar440 Offline
P
Indiana
If you don't care about AM reception, just about anything will work for FM . Hide the antenna up under the dash or use about a 30" piece of copper wire and wire tie it to something. For AM you will need some kind of a mast.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: NE1 every try a "hidden" antenna? [Re: Pentastar440] #280149
04/09/09 12:26 AM
04/09/09 12:26 AM
Missouri
NFURY8 Offline
super street
NFURY8  Offline
super street
Missouri
Kwik Wire makes one that is flexible, easily routed and $15. I haven't got it permanently installed yet, but I have tested it in a couple places and the results have been excellent. It says it is low power, but I was able to pickup everything my new factory radios could, including a couple stations I know have low power signals.
http://www.kwikwire.com/ac_antennas.html
C-Body DryDock Bigger is Better!
