Page 2 of 3 1 2 3
Re: DARE K members and front ends [Re: mr2performance] #280054
04/07/09 11:43 AM
04/07/09 11:43 AM
Orlando Florida
blown572dart Offline
Orlando Florida
Hey Fred, save your money, you're going to need it..... we got started today.
Yea he's going to need it because if he buy's that DARE part your going to have to fix it up..
Re: DARE K members and front ends [Re: blown572dart] #280055
04/07/09 12:38 PM
04/07/09 12:38 PM
Oklahoma
silverfish Offline
silverfish  Offline
Oklahoma
I had one and it was awful. It had bumpsteer problems and the shimmy problem. It would shake so bad when you hit the brakes after the finish line that is would shake the tach loose from the steering column! I took it to a chassis shop and had some custom ball joint arms made for it to get the bumpsteer out and got most of the shimmy out after a while also. Then came along my big wheelie mishap and it took care of the DARE k member for me. Now I have an Alterktion and couldn't be happier with it! Here is a pic of the custom ball joint arm I had made if it helps any....
Re: DARE K members and front ends [Re: silverfish] #280056
04/07/09 12:46 PM
04/07/09 12:46 PM
Chicagoland
chargerron69 Offline
Chicagoland
if its the guy in indiana i would deal with him at all. i have heard waaaay too many horror stories about that guy.
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: DARE K members and front ends [Re: chargerron69] #280057
04/07/09 03:00 PM
04/07/09 03:00 PM
L.I. N.Y. Hemi Street
HemiGreg Offline
HemiGreg  Offline
Them there Dare K members are not safe for 160 mph plus cars. If your going to run one you will spend 2X as much trying to make it safe before you can run. yea they seem ok at 100 mph but big end stopping and control is dangerous!!!!!!!!
cut it out and be safe---or take insurance out big time and name me beneficory-LOL.
but serious-stay clear for your useage!!!!
Re: DARE K members and front ends #280058
04/07/09 05:41 PM
04/07/09 05:41 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Fred
Do a search of DARE {Dave Adolette(sp?)Racing Electronics} here on MOPARTS, It wont come up good.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: DARE K members and front ends [Re: W.I.N. Racing] #280059
04/07/09 06:25 PM
04/07/09 06:25 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Fred
RUN do not walk away from anything to do with that nut. PM me or call me for all the sordid details.
JUNK!
Re: DARE K members and front ends [Re: sasquatch] #280060
04/07/09 06:56 PM
04/07/09 06:56 PM
Anonymous OP
Anonymous OP
fred, its not worth the money to fix it, walk away fast! dare k frames suckkkk.
Re: DARE K members and front ends [Re: Lil Demon] #280061
04/07/09 06:58 PM
04/07/09 06:58 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
So - my car is referenced in here with the Dare K member. With stock steering arms, it had horrible bumpsteer. With LRT arms, bumpsteer mostly gone, but now has the shimmy on the top end when the front gets loaded.
Not to hi-jack this, but: Who makes a good K member that eliminates these issues? What else would need to be purchased? I have Magnum Force tubular uppers, stock LCAs, LRT steering arms, Flaming River Pinto Rack, and Coil-Overs.
I'm already maxed out on the offset at 2.25".
Al & lil demon, maybe I'm wrong but it sounds like you are blaming LRT for trying to help you!!
I don't know how or why you bought the Dare POS.(should've done homework)
So LRT sells you HIS steering arms built for LRT's K and you sound like you are mad that it didn't solve the problem. He didn't design the dare k or have it in his shop to see how dare built it.
Lil demon you could buy LRT's K minus the arms and rack. I have the 3rd one he built and it works great!
I was just at Byron dragway first day open this year(green-no rubber) went mid 9s @ 136mph smooth as silk and no brake shimmy. I know LRT's K works! Don
Re: DARE K members and front ends [Re: sasquatch] #280062
04/07/09 07:07 PM
04/07/09 07:07 PM
mid Ga.
W5Dart378 Offline
W5Dart378  Offline
mid Ga.
I run one. I bought before There were other options. It forced me to learn all about the ft suspension and steering geometry. I'm on my second generation steering arms and planning on the third. Over the 3-4 years of screwing with it I have raised the rack 3", centered it and lowered the k frame 3/4". It is pretty low but saves the oil pan. The shimmy comes and goes, but nothing like when I first ran it.
69 340 swinger streetcar 8.13 1/8th w/1.90 60ft w/ 3.55s 69 422W9 Dart stock suspension,5.27 on 275/60s,single bar plate
Re: DARE K members and front ends [Re: cudadon] #280063
04/07/09 08:58 PM
04/07/09 08:58 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
Um - No - I'm not blaming LRT for anything. The Dare K memberwas on the car when I bought it and I didn't know any better at the time. I talked to LRT and he said his arms would mostlikely correct the bumpsteer. They did improve it somewhat - but they introduced the shimmy - never had that before.
LRT has no blame here. I need to get the spindle face plates machined .250 as LRT recommends to see if that solves the shimmy.
I have no desire to spend a ton of money for a new K frame. Before I do that - I'll put an entire new front clip in it and drop a bunch of weight.
Re: DARE K members and front ends [Re: W.I.N. Racing] #280064
04/07/09 09:10 PM
04/07/09 09:10 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
RMS also makes one with mini torsion bars now,Ive seen Bills stuff and I have his strut rods on the 65.Nice stuff.Rocky
Chrysler Firepower
Re: DARE K members and front ends [Re: therocks] #280065
04/07/09 09:46 PM
04/07/09 09:46 PM
toronto ontario
badwej Offline
badwej  Offline
toronto ontario
I have one it works good now only took 3 years and lots of changes. Where are you getting it from I thought Dare was not biulding his junk anymore.
badwej@hotmail.com Sean Parker Toronto Ontario Canada
Re: DARE K members and front ends [Re: badwej] #280066
04/07/09 09:52 PM
04/07/09 09:52 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Fred - that K frame combined with the red horse fittings will be one hell of a combination!
Re: DARE K members and front ends [Re: cudadon] #280067
04/07/09 10:40 PM
04/07/09 10:40 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Um Cudadon...NO not blaming LRT for the POS K member. I am happy you have been happy with your chassis guy, you should be. I do however have some issue with the timeliness of delivery of the parts for sure. I was not privy to both sides of the conversation so can only go by what I was told.
my suggestion from the beginning has been to SH*T can it and go another direction. I dont own the car just try to do what customers want, that is why I left parts sourcing to lil. I have also had experience with an AJE Mopar kit and we threw it away and put in a lightened stock K.
Bottom line is the dare K is a huge POS..LRT is making pieces that solve some of the issues with them for sure. Should he be applauded for his efforts, maybe, or is he a business man who saw an oppourtunity and has the means to capitalize on it, I will let folks form their own opinions on that.
Re: DARE K members and front ends [Re: Al_Alguire] #280068
04/07/09 10:51 PM
04/07/09 10:51 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
For the record, Rob (LRT) is not making pieces to repair a DARE K-frame setup. A DARE is a rip-off of Rob's original design with some differences. One of the differences is the steering arms.
I have never met Rob but have referred a few friends to him that had front end troubles. He is a very knowledgeable guy who doesn't want to see DARE's junk killing people.
I met with Dave Aydolette (DARE) when I discovered what a piece of crap my AJE is. I knew Dave was a tool when he told me that simply swapping LBJ's side for side would not affect bump steer and Ackerman.
Post deleted by Defbob #280069
04/08/09 08:46 AM
04/08/09 08:46 AM
Anonymous OP
Anonymous OP
Re: DARE K members and front ends #280070
04/08/09 08:57 AM
04/08/09 08:57 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
never seen as much negavtivity on a product since I join this board 6 or 7 years ago
It is what it is Fred,Facts don't lie.Everyone That I know that had a Dare K member had problems and either reworked them or scrapped them.This has been posted and hashed over many times in the past.Aren't you glad you asked?
Re: DARE K members and front ends [Re: B G Racing] #280071
04/08/09 10:48 AM
04/08/09 10:48 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
When is the crucifixion? I’d like to attend.
Yeah, having never personally owned, or worked on one I’d run from anything that had one. I’d also never want to line up next to a car with one. The one I have seen looked like a funny car in tire wobble backing up.
Re: DARE K members and front ends [Re: dthemi] #280072
04/08/09 11:02 AM
04/08/09 11:02 AM
Oklahoma
silverfish Offline
silverfish  Offline
Oklahoma
Yeah I forgot about that problem. When I would back up the tops of the front tires would just lay in bad! The new balljoint arms that I had made didn't even take that out! Just a poor design. I guess thats why he doesn't make them anymore....well and the fact that he never even tried to help anyone out and never returned phone calls!
Re: DARE K members and front ends [Re: silverfish] #280073
04/08/09 12:19 PM
04/08/09 12:19 PM
IL
DRAGRCR632 Offline
super street
DRAGRCR632  Offline
super street
IL
WOW
for the record ive never made and repair peices for the dare crap
what i did is i had an overwhelling phone
calls for help with thier dare K frame and
tried to help and biggest problem was the lack
of steering arms from dare so all i did was sell
mine to people and it helped about 75 % of them
as for demons steering arms and lack of timely fashion???? he called sent money and i make
all my peices one at a time per order so
if i have 10 orders he is 11th in line
i even sent him another set on alum tierod sleeves for free cause he didnt know what he need
so i gave him what everyone esle had used????
and that ended up short
just for the record ive STOPPED selling my arms to ANYONE that doesnt have my K frame all ready
i decided that im not goin to put up with the
bashing here on moparts and other places
its funny ive stoppe comin on here also but a customer of mine what me to post
ive tried from the get go to make a product for
the mopar crowd that was there but the ones out there didnt work but of the few people that decied to voice thier problems on here and bash
me pretty hard i will no long come on here
and will no longer help ANYBODY except LRT
K frame customers PERIOD
LRT
Page 2 of 3 1 2 3
