manual steering box swap/with motor in car #2800531
07/24/20 09:37 AM
07/24/20 09:37 AM
Penna
70satelliteguy Offline OP
Penna
Can this be done in a 70 B body without removing the motor?
Re: manual steering box swap/with motor in car [Re: 70satelliteguy] #2800555
07/24/20 10:46 AM
07/24/20 10:46 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
I did it on a '65 coronet with an RB engine and headers. wasn't easy, but doable. IIRC I had to raise the engine on the driver side and remove the header. cast exhaust manifolds would make the swap much easier.
Re: manual steering box swap/with motor in car [Re: lewtot184] #2800628
07/24/20 01:16 PM
07/24/20 01:16 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Heck, we had a guy here recently that did that on an A body, I imagine a B is not as difficult, but I have never owned a B, so take it for what it's worth, diddly, lol.
Re: manual steering box swap/with motor in car [Re: Sniper] #2800665
07/24/20 03:28 PM
07/24/20 03:28 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
I went from power to manual without touching anything else on a big block 70 E-body with headers.
Re: manual steering box swap/with motor in car [Re: challenger70] #2800676
07/24/20 04:35 PM
07/24/20 04:35 PM
MN
W
Willie68coronet Offline
W
MN
I did it on my68 coronet a few years ago, it had a 383 with hedman 1-3/4 headers. I had to raise the drivers side of the engine. Getting the manual box in was easier than getting the power box out. One of the best changes I made.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: manual steering box swap/with motor in car [Re: Willie68coronet] #2800904
07/25/20 10:02 AM
07/25/20 10:02 AM
Penna
Penna
Willie I already have a manual box in the car now. It has play even after tightening it up. This will be simply a manual to manual swap. I imagine is should be easier???? Any recommendations for a new box for a mostly drag car?
Mike
Re: manual steering box swap/with motor in car [Re: 70satelliteguy] #2802075
07/28/20 10:51 AM
07/28/20 10:51 AM
IL
furious70 Offline
furious70  Offline
IL
I've done PS box R&R in my 68 Charger with 440 and headers - needed to take the header loose and down and take the box out from the top. Manual box should be 'easy'.
70 Sport Fury
68 Charger
69 Coronet
72 RR
