Stage V Hemi heads, zero hits on Search function #2798982
07/20/20 03:24 PM
07/20/20 03:24 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Wanted to read about the Stage V heads. I know they have been discussed on here.
Search function does not like "Stage V" or "Stage 5".
Wanted to read about others problems/experiences/successes.
Re: Stage V Hemi heads, zero hits on Search function [Re: hemienvy] #2799010
07/20/20 04:15 PM
07/20/20 04:15 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
My brother, myself and friends of ours have used the big valve and Millennium heads in blown and N/A applications with zero issues. The Barton rockers are a good upgrade, as well.
They are quality castings and make decent power, considering the head is quite dated compared to many current brand x offerings.
Re: Stage V Hemi heads, zero hits on Search function [Re: jim sciortino] #2799020
07/20/20 04:50 PM
07/20/20 04:50 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Hello Jim,
I am considering getting the regular port heads. At the moment, my question is, Do they need external oil drainback lines ?
Or, does it depend on which block they would go on ? Do some blocks have drainback provisions and other blocks not ?
Re: Stage V Hemi heads, zero hits on Search function [Re: hemienvy] #2799234
07/21/20 07:48 AM
07/21/20 07:48 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I am using the Stage V replacement heads . They do not require external oil drain-back lines. The block is a World aluminum .
I am also using the Stage V rockers and I am happy with them as well.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Stage V Hemi heads, zero hits on Search function [Re: Hemi Allstate] #2799294
07/21/20 10:15 AM
07/21/20 10:15 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Thank you Allstate !
Re: Stage V Hemi heads, zero hits on Search function [Re: hemienvy] #2799366
07/21/20 12:50 PM
07/21/20 12:50 PM
Stage V offers several different castings, race versus street, that will bolt onto a stock or after market block with no issues scope
Nice, good parts up
Re: Stage V Hemi heads, zero hits on Search function [Re: Cab_Burge] #2799373
07/21/20 01:11 PM
07/21/20 01:11 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Thanks Cab,
There's still no Search hits, even after this post !
Re: Stage V Hemi heads, zero hits on Search function [Re: hemienvy] #2799420
07/21/20 02:53 PM
07/21/20 02:53 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The search functions on most boards leaves alot to be desired and doesn't work more than half the time.
You'll have a whole lot more reading material doing it this way:
Search #1
or this way
Search #2
Rich H.
Esse Quam Videri
Re: Stage V Hemi heads, zero hits on Search function [Re: hemienvy] #2799495
07/21/20 06:15 PM
07/21/20 06:15 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Call me. I can answer any questions you have about those heads.
fastmanefi.com
Rich Nedbal
