Re: Starting to work on the Duster
[Re: AndyF]
#2795831
07/12/20 02:15 PM
07/12/20 02:15 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
Every guy that builds rear ends right now are scratching their heads looking at those pictures. You are making this WAY more complicated than it has to be Just an old beam style inch pound torque wrench is all you need.
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: racerx]
#2796494
07/14/20 12:29 PM
07/14/20 12:29 PM
Posts: 31,061 Oregon
AndyF
Andy are you welding your own fuel tank together your self? No, I don't have a TIG. I'm okay with a MIG but I don't have much TIG experience. I take the TIG welding over to the local chassis shop and let the pros do it.
[Re: AndyF]
#2796628
07/14/20 05:44 PM
07/14/20 05:44 PM
Posts: 4,075 Mo.
racerx
Mo.
Andy are you welding your own fuel tank together your self? No, I don't have a TIG. I'm okay with a MIG but I don't have much TIG experience. I take the TIG welding over to the local chassis shop and let the pros do it. Got it looks Good.
[Re: racerx]
#2796818
07/15/20 07:32 AM
07/15/20 07:32 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
That looks really nice, I need to do a new tank. I have a sump a friend of mine and I made that didn't turn out as we wanted it to. Its amazing the amount of baffling we have in the sump and you can still hear the pump change tone when you get on the brakes, even with lots of fuel. It doesn't cause a pressure loss but something changes because you can here the pump when you normally can't.
I need to work in a tank like you have made but under the car.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2796874
07/15/20 10:55 AM
07/15/20 10:55 AM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
I need to work in a tank like you have made but under the car. Something like this? This is the tank I have in my Duster. Got it a few years back from a place called Hot Rod City Garage which unfortunately is no longer business. Saved 18lbs from the stock tank. Fully baffled and narrowed to fit between 3" exhaust.
'71 Duster '72 Challenger '17 Ram 1500
[Re: Bad340fish]
#2796992
07/15/20 02:05 PM
07/15/20 02:05 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
I need to work in a tank like you have made but under the car. If you have no pressure change, I would say its just a sound change from the fuel load change on the outer walls of the tank, the Dampening change from front to back, just my opinion .
[Re: RMCHRGR]
#2797254
07/16/20 06:24 AM
07/16/20 06:24 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
I need to work in a tank like you have made but under the car. Something like this? This is the tank I have in my Duster. Got it a few years back from a place called Hot Rod City Garage which unfortunately is no longer business. Saved 18lbs from the stock tank. Fully baffled and narrowed to fit between 3" exhaust. That's impressive.
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: RapidusMaximus]
#2797280
07/16/20 08:42 AM
07/16/20 08:42 AM
Posts: 34,939 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Look up Mark Winchester on Facebook , Winchester metal work , he makes all kinds of super nice ,custom valve covers , puke tanks, fuel cells ..
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: 71TA]
#2830172
10/07/20 10:37 PM
10/07/20 10:37 PM
AndyF
Why did you switch from the Dana to the 9" ? Easier to work on, doesn't take up so much space plus I wanted a gear ratio that you can't get in a Dana 60.
