Page 32 of 34 1 2 30 31 32 33 34
Re: Starting to work on the Duster [Re: AndyF] #2795831
07/12/20 02:15 PM
07/12/20 02:15 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Every guy that builds rear ends right now are scratching their heads looking at those pictures. You are making this WAY more complicated than it has to be twocents Just an old beam style inch pound torque wrench is all you need.
64 Plymouth Savoy
Dana 60
Re: Starting to work on the Duster [Re: AndyF] #2796192
07/13/20 02:58 PM
07/13/20 02:58 PM
AndyF Offline OP
AndyF  Offline OP
Getting close on the new gas tank. Have it mocked up, just need to add another mount and then weld the lid on .
Re: Starting to work on the Duster [Re: AndyF] #2796194
07/13/20 02:59 PM
07/13/20 02:59 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
VERY nice !!!!
Re: Starting to work on the Duster [Re: CSK] #2796232
07/13/20 04:46 PM
07/13/20 04:46 PM
oregon
greendart408 Offline
oregon
Taking it to mopar drags Sunday?
Re: Starting to work on the Duster [Re: AndyF] #2796351
07/13/20 11:36 PM
07/13/20 11:36 PM
AndyF Offline OP
AndyF  Offline OP
Here are a couple more pictures with the top off showing the baffles inside and the sump built into the corner. The sump is 4 inches deep and I can lower the pump down into it so I should be able to maintain fuel pressure all the way to empty.
Re: Starting to work on the Duster [Re: AndyF] #2796414
07/14/20 09:26 AM
07/14/20 09:26 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Andy are you welding your own fuel tank together your self?
Re: Starting to work on the Duster [Re: racerx] #2796494
07/14/20 12:29 PM
07/14/20 12:29 PM
AndyF Offline OP
AndyF  Offline OP
No, I don't have a TIG. I'm okay with a MIG but I don't have much TIG experience. I take the TIG welding over to the local chassis shop and let the pros do it.
Re: Starting to work on the Duster [Re: AndyF] #2796628
07/14/20 05:44 PM
07/14/20 05:44 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Got it looks Good. up
Re: Starting to work on the Duster [Re: racerx] #2796818
07/15/20 07:32 AM
07/15/20 07:32 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That looks really nice, I need to do a new tank. I have a sump a friend of mine and I made that didn't turn out as we wanted it to. Its amazing the amount of baffling we have in the sump and you can still hear the pump change tone when you get on the brakes, even with lots of fuel. It doesn't cause a pressure loss but something changes because you can here the pump when you normally can't.
I need to work in a tank like you have made but under the car.
68 Barracuda Formula S 340
Re: Starting to work on the Duster [Re: Bad340fish] #2796874
07/15/20 10:55 AM
07/15/20 10:55 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Something like this? This is the tank I have in my Duster. Got it a few years back from a place called Hot Rod City Garage which unfortunately is no longer business. Saved 18lbs from the stock tank. Fully baffled and narrowed to fit between 3" exhaust.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Starting to work on the Duster [Re: Bad340fish] #2796992
07/15/20 02:05 PM
07/15/20 02:05 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
If you have no pressure change, I would say its just a sound change from the fuel load change on the outer walls of the tank, the Dampening change from front to back, just my opinion .
Re: Starting to work on the Duster [Re: RMCHRGR] #2797254
07/16/20 06:24 AM
07/16/20 06:24 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
That's impressive. up
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Starting to work on the Duster [Re: RapidusMaximus] #2797280
07/16/20 08:42 AM
07/16/20 08:42 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Look up Mark Winchester on Facebook , Winchester metal work , he makes all kinds of super nice ,custom valve covers , puke tanks, fuel cells ..
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Starting to work on the Duster [Re: AndyF] #2806686
08/08/20 08:27 PM
08/08/20 08:27 PM
AndyF Offline OP
AndyF  Offline OP
Got the new fuel tank installed and have had the car out for a few test miles. Everything seems to be working great so far. The fuel doesn't slosh around like it used to in the unbaffled tank. I have a lot of room in the trunk now since the new tank sits up between the tubs. I mounted the filter/regulator combo on the inside of the passenger tub so it is out of the way. All of the lines and wiring tuck up out of the way so that cleaned up the trunk space nicely. I need to patch the floor and then it will be ready to go.
Re: Starting to work on the Duster [Re: AndyF] #2828683
10/04/20 07:27 PM
10/04/20 07:27 PM
AndyF Offline OP
AndyF  Offline OP
New wheels and tires are here. Took about 4 months for the correct wheels to arrive. Weld sent the wrong wheels 8 weeks after I ordered them so they had to go back to Weld. Then they took about 6 more weeks to send the correct wheels. Tires were also backordered. The brakes took a few weeks from Baer but not too bad. The 9 inch is on order with Doctor Diff, should have it the end of the month or early in November and then I'll go to work on putting it in the car.
Re: Starting to work on the Duster [Re: AndyF] #2828687
10/04/20 07:37 PM
10/04/20 07:37 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Very nice !!!
Re: Starting to work on the Duster [Re: AndyF] #2829396
10/06/20 05:10 PM
10/06/20 05:10 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
That looks good Andy
Re: Starting to work on the Duster [Re: AndyF] #2830120
10/07/20 08:18 PM
10/07/20 08:18 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Why did you switch from the Dana to the 9" ?
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Starting to work on the Duster [Re: 71TA] #2830172
10/07/20 10:37 PM
10/07/20 10:37 PM
AndyF Offline OP
AndyF  Offline OP
Easier to work on, doesn't take up so much space plus I wanted a gear ratio that you can't get in a Dana 60.
Re: Starting to work on the Duster [Re: AndyF] #2849182
11/20/20 06:46 PM
11/20/20 06:46 PM
AndyF Offline OP
AndyF  Offline OP
The new 9 inch assembly from Strange Engineering is here. Need to get it unpacked and mount the brakes up before sliding it under the car. Then I can sell the existing S60 setup.
