Ignition 71 340 swinger electronic or point? #278921
04/05/09 10:59 PM
04/05/09 10:59 PM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
Trying to confirm what ignitions systems would have came out in the Canadian 340 71 Darts. I am in restoring mine and trying to make it as correct as possible. I know there was a shift in 71 340 to electronic and was wondering if anyone never the exact time line. thanks
1971 340 Swinger Canadian Car
1972 Dodge Dart Prostreet 440
2013 Dodge Ram 1500
Re: Ignition 71 340 swinger electronic or point? [Re: dalei989] #278922
04/06/09 02:13 AM
04/06/09 02:13 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Not 100% so wait for more opinions, but the engine color changed from orange to blue in late March to around the first or second week of April, and i think most were points till the very end of production in 71, and electronic was a option, maybe made it to some very late 71's as standard?
Re: Ignition 71 340 swinger electronic or point? [Re: dalei989] #278923
04/06/09 10:14 AM
04/06/09 10:14 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
you should be able to find the screw holes on your left hand inner fender perhaps?(i assume thats where it was)
i know a 71 cuda that i sold for a friend had on the bottom of the build sheet "special order electronic ignition"
engine harness still there or it it gone?
Re: Ignition 71 340 swinger electronic or point? [Re: chrisf] #278924
04/06/09 10:23 AM
04/06/09 10:23 AM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
no screw holes in my inner, of course when I bought the car it was a mess. It has electronic ignition mounted on the firewall. I bought a oem wiring harness for a 71 340 demon and it is point ignition. thanks
2013 Dodge Ram 1500
Re: Ignition 71 340 swinger electronic or point? [Re: dalei989] #278925
04/06/09 12:18 PM
04/06/09 12:18 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Do you have a Broadcast Sheet or a fender tag? If so what is the Scheduled Production Date?
Re: Ignition 71 340 swinger electronic or point? [Re: ScottSmith_Harms] #278926
04/06/09 12:59 PM
04/06/09 12:59 PM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
May 13 is my build date. thanks
2013 Dodge Ram 1500
Re: Ignition 71 340 swinger electronic or point? [Re: dalei989] #278927
04/06/09 01:20 PM
04/06/09 01:20 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Although I've heard that the changeover might have taken place around the same time as the engine color (late March, Early April) some factory literature shows that the "official" date was (if I am remembering correctly) May 21- June 1 which is the generally accepted running changover date.
Re: Ignition 71 340 swinger electronic or point? [Re: ScottSmith_Harms] #278928
04/06/09 01:23 PM
04/06/09 01:23 PM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
where were modules actually mounted in the engine bay. Does anyone have any pics of the 71 demon engine bays with electronic?
2013 Dodge Ram 1500
Re: Ignition 71 340 swinger electronic or point? [Re: dalei989] #278929
04/06/09 03:58 PM
04/06/09 03:58 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I cant seem to locate it right now, but I have a factory memo dated 5/14/71 that states "effective 5/17/71 all 340 manual trans equipped vehicles will have Electronic Ignition System N23".
Whether it actually took place then, I am not certain and no mention is made of automatic 340's.
Re: Ignition 71 340 swinger electronic or point? [Re: dalei989] #278930
04/06/09 08:30 PM
04/06/09 08:30 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
I have a 71 Road Runner that has a SPD of 7/7/71. I'll be darned if I can find any evidence of it ever having electronic ignition.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Ignition 71 340 swinger electronic or point? [Re: sixpackbee] #278931
04/06/09 10:17 PM
04/06/09 10:17 PM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
I think I am going to go with a point ignition system as there seems to be enough documentation to make me think it would be correct. thanks
2013 Dodge Ram 1500
Re: Ignition 71 340 swinger electronic or point? [Re: dalei989] #278932
04/06/09 10:33 PM
04/06/09 10:33 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
And that is probably the right assumption.
Re: Ignition 71 340 swinger electronic or point? [Re: ScottSmith_Harms] #278933
04/06/09 10:37 PM
04/06/09 10:37 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
agreed, you're safe with the points as this bulletin dated May 6,71 doesn't actually state when the change was to take place.
Re: Ignition 71 340 swinger electronic or point? [Re: mccannix] #278934
04/07/09 06:35 PM
04/07/09 06:35 PM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
Finally we got a hold of a owner of a survivor 71 340 4 speed canadian swinger. His is basicly untouched and his is a point ignition car, dual point distributor. thanks for all the input.
2013 Dodge Ram 1500
Re: Ignition 71 340 swinger electronic or point? [Re: dalei989] #278935
04/07/09 06:46 PM
04/07/09 06:46 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Lots of 71's were points ign. the question is, what was his cars Scheduled Production Date?
Re: Ignition 71 340 swinger electronic or point? [Re: ScottSmith_Harms] #278936
04/07/09 07:39 PM
04/07/09 07:39 PM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
There were two batchs of Swingers made with 340's in 71 aprox 50 were plain jane swinger specials and were sold by a dealership in Edmonton Alberta Crosstown Motors, these had a build date of May 7 1971 and 25 were sold in Regina Sask Crestview motors. These had the H2XW interiors and some chrome trim added and these had a build date of May 13. The fellow with the survivor car has a Crestview car and mine is a Crestview car both with build dates of May 13. thanks
2013 Dodge Ram 1500
Re: Ignition 71 340 swinger electronic or point? [Re: dalei989] #278937
04/07/09 08:57 PM
04/07/09 08:57 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That sounds like good reasoning. What is the source of the above information?
Re: Ignition 71 340 swinger electronic or point? [Re: ScottSmith_Harms] #278938
04/07/09 09:27 PM
04/07/09 09:27 PM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
A fellow by the name of Dan Rasmussen did the majority of research on these cars. About 8 years ago I bought my dart in Edmonton, started research and collecting data and came across Dan, at this point he was getting into E bodys and out of the A bodys so I bought a donor car from him and his research. I have a registry on these cars and friend who purchased a rare 72 340 Dart have been playing with this ever since. A fellow named Franco has a nice article on them, maybe alittle out dated, here is the link http://www3.sympatico.ca/f.bevil/71Swinger340.html
which hopefully I did correctly. I believe out of the 65 - 75 71 darts made there are aprox 21 that we know of still living. thanks
2013 Dodge Ram 1500
Re: Ignition 71 340 swinger electronic or point? [Re: dalei989] #278939
04/07/09 10:45 PM
04/07/09 10:45 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
Very cool info! I had heard of the 71 340 Swingers, but have never seen one until now. One question I have, was there ever a 70-71 Scamp 340 made in Canada? I can recall seeing a white 71 Scamp around 1979 that had twin scoops and a 340. Unfortuneatly I did not get the VIN since I had just had my 69 Dart GTS for a year at that point.
JB Rhinehart, Realist
A-Body's RULE!
Re: Ignition 71 340 swinger electronic or point? [Re: Rhinodart] #278940
04/07/09 10:59 PM
04/07/09 10:59 PM
Gibsons BC Canada
dalei989 Offline OP
dalei989  Offline OP
Gibsons BC Canada
I am not sure, have never heard of one but with Mopars you never know:)
2013 Dodge Ram 1500
