Black Wrinkle Finish #2788361
06/23/20 09:01 AM
06/23/20 09:01 AM
montana
BANDIT Offline OP
BANDIT  Offline OP
montana
Hey guys, I’m refinishing a set of Hemi valve covers for a buddy, what paint and procedure do you use to achieve the wrinkle finish. Not a Gold show car job, just something acceptable will do. Thanks , Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Black Wrinkle Finish [Re: BANDIT] #2788362
06/23/20 09:07 AM
06/23/20 09:07 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You'll probably only be able to find VHT wrinkle. I know its a hard thing for a guy to do but ...follow the directions on the can.
Re: Black Wrinkle Finish [Re: Stanton] #2788364
06/23/20 09:16 AM
06/23/20 09:16 AM
robertop Offline
robertop  Offline
I did a same set few years ago and quickly realized that paint would not do for such an item. I went with powder coating with excellent results
Re: Black Wrinkle Finish [Re: Stanton] #2788367
06/23/20 09:19 AM
06/23/20 09:19 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yep, the directions are good. Lay it on pretty thick, until it's just about to run.
Let it air dry. Alot of times...it won't wrinkle and folks freak out.
Apply a little heat, and the wrinkle effect will kick in.
Rich H.
Esse Quam Videri
Re: Black Wrinkle Finish [Re: ZIPPY] #2788409
06/23/20 10:41 AM
06/23/20 10:41 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have done a lot of wrinkle finishes over the years and have found that even coats along with the suggested heat works awesome. I have used either a kerosene or 115V oil filled radiant heater as the source of heat. If you watch it, it will wrinkle as the heat travels across the part. beer
Re: Black Wrinkle Finish [Re: TJP] #2788411
06/23/20 11:01 AM
06/23/20 11:01 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
A friend of mine had used the various commonly available aerosols with mixed results. He was at the Harley dealer getting some parts and they had their brand of wrinkle paint. It was expensive, but gave him perfect first time results with 100% wrinkle.
Re: Black Wrinkle Finish [Re: Lee446] #2788422
06/23/20 11:27 AM
06/23/20 11:27 AM
central il.
second 70 Offline
second 70  Offline
central il.
Agree on the Harley paint.
Re: Black Wrinkle Finish [Re: second 70] #2788429
06/23/20 11:43 AM
06/23/20 11:43 AM
montana
BANDIT Offline OP
BANDIT  Offline OP
montana
Thanks guys, there is a Harley shop about 50 miles away, I’ll give it a try. Jim.
4600 DA
Re: Black Wrinkle Finish [Re: BANDIT] #2788433
06/23/20 11:54 AM
06/23/20 11:54 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I suspect the Harley stuff is repackaged VHT ... just 3 times the price. The same stuff was available back in the 70's and today's product doesn't work any better or worse. Back then I used to bake it in the oven at well over the recommended 200 degrees. It stood up to anything you could throw at it. The only way to remove it was to sandblast it - not bead blast ... SANDBLAST !!
Re: Black Wrinkle Finish [Re: Stanton] #2788489
06/23/20 02:36 PM
06/23/20 02:36 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
I know it is not what you where looking for but I used some black Dupli color truck bed coating and it looked really nice and durable. I think it looks close to the wrinkle finish.
Re: Black Wrinkle Finish [Re: mopars4ever] #2788493
06/23/20 02:54 PM
06/23/20 02:54 PM
montana
BANDIT Offline OP
BANDIT  Offline OP
montana
I had thought about the bed liner stuff too. Jim
4600 DA
Re: Black Wrinkle Finish [Re: BANDIT] #2788495
06/23/20 03:06 PM
06/23/20 03:06 PM
montana
BANDIT Offline OP
BANDIT  Offline OP
montana
You guys that used the Harley paint, did you have to bake them after painting? Jim
4600 DA
Re: Black Wrinkle Finish [Re: BANDIT] #2788507
06/23/20 03:34 PM
06/23/20 03:34 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
When I use the VHT paint, I let it sit for maybe 15 minutes so it gets a little tacky.(less likely to run when heat applied) Then I hit it with a heat gun. Make sure to move the heat around and don't have it set on high air speed. One area will start to wrinkle and you can follow the leading edge along with the head gun. If you hold the heat in one spot too long it will bubble.
You don't have to use heat if you don't want to. When redoing my plastic Challenger heater controls, I just let the parts sit in the sun.
Re: Black Wrinkle Finish [Re: burdar] #2788513
06/23/20 04:16 PM
06/23/20 04:16 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
There are youtube vids on spraying wrinkle paint. You have to do three coats each at different angles etc. It does require some practice to nail it.
Re: Black Wrinkle Finish [Re: BANDIT] #2788560
06/23/20 06:10 PM
06/23/20 06:10 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Don’t use bedliner. That is just silly. I’ve done many air cleaners and valve covers, the time between coats and heat is very important. Also shake the cans some for a couple day before painting.
Look at this old thread.
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/1943417/Searchpage/1/Main/167993/Words/%2BWrinkle/Search/true/re-quick-survey-best-rattle-can-wrinkle-finish.html#Post1943417
Re: Black Wrinkle Finish [Re: BANDIT] #2788599
06/23/20 07:30 PM
06/23/20 07:30 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
VHT and Harley both work well. The more you apply at one time and the more heat you apply during the drying process will determine the amount of wrinkle. I just use a hair dryer. I can see where powder coat would be a bit tougher finish, but I have never had any issues with the VHT, so I am not sure that the powder coat would be worth the extra coin.
Master, again and still
