Black Wrinkle Finish
#2788361
06/23/20 09:01 AM
06/23/20 09:01 AM
Posts: 422 montana
BANDIT
montana
Hey guys, I’m refinishing a set of Hemi valve covers for a buddy, what paint and procedure do you use to achieve the wrinkle finish. Not a Gold show car job, just something acceptable will do. Thanks , Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
Re: Black Wrinkle Finish
[Re: Stanton]
#2788367
06/23/20 09:19 AM
06/23/20 09:19 AM
Posts: 17,860 S.E. Michigan
ZIPPY
S.E. Michigan
Yep, the directions are good. Lay it on pretty thick, until it's just about to run. Let it air dry. Alot of times...it won't wrinkle and folks freak out. Apply a little heat, and the wrinkle effect will kick in.
Rich H.
Esse Quam Videri
[Re: Lee446]
#2788422
06/23/20 11:27 AM
06/23/20 11:27 AM
Posts: 1,708 central il.
second 70
central il.
A friend of mine had used the various commonly available aerosols with mixed results. He was at the Harley dealer getting some parts and they had their brand of wrinkle paint. It was expensive, but gave him perfect first time results with 100% wrinkle. Agree on the Harley paint.
[Re: second 70]
#2788429
06/23/20 11:43 AM
06/23/20 11:43 AM
Posts: 422 montana
BANDIT
montana
Thanks guys, there is a Harley shop about 50 miles away, I’ll give it a try. Jim.
[Re: mopars4ever]
#2788493
06/23/20 02:54 PM
06/23/20 02:54 PM
Posts: 422 montana
BANDIT
montana
I had thought about the bed liner stuff too. Jim
[Re: BANDIT]
#2788495
06/23/20 03:06 PM
06/23/20 03:06 PM
Posts: 422 montana
BANDIT
montana
You guys that used the Harley paint, did you have to bake them after painting? Jim
