Page 36 of 48 1 2 34 35 36 37 38 47 48
Re: Modern Bullitt build [Re: Keepat] #2775482
05/17/20 04:38 PM
05/17/20 04:38 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I installed the steering column and the custom thicker grip steering wheel I made a few years ago. The thicker steering wheel is so much more comfortable then the thin original.
Pat
https://www.facebook.com/495913940789909/posts/522539141460722?d=n&sfns=mo
Re: Modern Bullitt build [Re: Keepat] #2775558
05/17/20 07:41 PM
05/17/20 07:41 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
So much cool stuff!
But I think I like the thick blocks of foam for laying on the best!
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Modern Bullitt build [Re: DynoDave] #2778261
05/26/20 08:21 AM
05/26/20 08:21 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted by DynoDave
So much cool stuff!
Back and knees saver;-)
Re: Modern Bullitt build [Re: Keepat] #2778262
05/26/20 08:22 AM
05/26/20 08:22 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Installed the right side vent and door glass this week end. Very happy with the aftermarket power window regulator.
Pat
Re: Modern Bullitt build [Re: Keepat] #2782154
06/06/20 03:28 PM
06/06/20 03:28 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I Installed the passenger side rear window and trim. The AMD quarter glass was a heavy 1/16” taller on the rear 12 inches compared to the original. So I had to sand it down with a DA sander to get the best fit. All of the AMD glass has a rough finish on edge so I use the DA sander starting with 60 grit and working my way to 180 to polished edges that shows.
Pat
Re: Modern Bullitt build [Re: Keepat] #2785897
06/15/20 11:34 PM
06/15/20 11:34 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Your a brave man! last time I was "polishing" the edge of tempered side glass with a DA, it was going great one moment, then the next the glass just sort of disappeared from my hand! got a little "gun shy" after that..Lol!...great work as always!
Mike
Re: Modern Bullitt build [Re: DAYCLONA] #2787178
06/19/20 05:10 PM
06/19/20 05:10 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Mike
Mike,
Working with tempered glass is never fun, but as long as you do not let the glass get hot it can work. I would only sand the edge of the glass for about 30 seconds then stopping to let it cool.
Thank you!
Pat
Re: Modern Bullitt build [Re: Keepat] #2788722
06/24/20 07:35 AM
06/24/20 07:35 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Another big part out of storage and bolted on the car. Little by little taking shape;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2795566
07/11/20 05:51 PM
07/11/20 05:51 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
With all of the brakes bled, I mounted all 4 wheels for the first time in many years.
Pat
Re: Modern Bullitt build [Re: Keepat] #2795666
07/12/20 12:26 AM
07/12/20 12:26 AM
Newton, KS
70B5Cuda Offline
70B5Cuda  Offline
Newton, KS
WOW....that's all I've got. Can't wait to see pics of it on the street
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Modern Bullitt build [Re: 70B5Cuda] #2796047
07/13/20 06:50 AM
07/13/20 06:50 AM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
This car is amazing.
Earning every penny of that moderator paycheck.
DBAP
Re: Modern Bullitt build [Re: not_a_charger] #2796410
07/14/20 09:16 AM
07/14/20 09:16 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
iagree
drool drool
Re: Modern Bullitt build [Re: UCUDANT] #2796553
07/14/20 02:41 PM
07/14/20 02:41 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
TOO PERFECT!
I would be afraid to drive it!
'63 Dodge 330
11.19 @ 121 mph
Re: Modern Bullitt build [Re: 70B5Cuda] #2798300
07/18/20 01:05 PM
07/18/20 01:05 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Me too! Thanks!
Re: Modern Bullitt build [Re: not_a_charger] #2798301
07/18/20 01:06 PM
07/18/20 01:06 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you!
Re: Modern Bullitt build [Re: GY3] #2798302
07/18/20 01:07 PM
07/18/20 01:07 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted by GY3
TOO PERFECT!
I’ll drive it!
Thanks!
Pat
Re: Modern Bullitt build [Re: Keepat] #2801415
07/26/20 04:46 PM
07/26/20 04:46 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Move the car from the hot Rod shop to my home to make room for my Brothers 65 Pontiac. The AC works much better in my home garage, and the four post lift will make it very easy to install the exhaust. I think it’s been about 35 years since I’ve last towed a car with a strap. This was only about 200 yards from my house but when I was a teenager I think my record was about 15 miles ;-)
Re: Modern Bullitt build [Re: Keepat] #2801597
07/27/20 06:07 AM
07/27/20 06:07 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Very nice Pat!
At first I thought you were going to say you drove it over!
Nice house garage with lift and house. Looks like you are on the water! Nice place.
I hope to see it in person one day.
-larry
Re: Modern Bullitt build [Re: larry4406] #2801772
07/27/20 03:05 PM
07/27/20 03:05 PM
mopar4don Offline
mopar4don  Offline
WOW
Re: Modern Bullitt build [Re: Keepat] #2801839
07/27/20 06:54 PM
07/27/20 06:54 PM
Red Deer, Alberta
Greenwood Offline
Greenwood  Offline
Red Deer, Alberta
This is absolutely the finest GenII Charger build out there, bar none. I have to comment on your wheels. Your "template" was always a good looking wheel, and you have done a masterful job of turning a wheel cover into a wheel. They're stunningly perfect. Outstanding!
