Re: Need help with shroud for a champion radiator!!
[Re: topside]
#2786052
06/16/20 03:16 PM
06/16/20 03:16 PM
Posts: 4,728 Moved to N.E. Tennessee
GomangoCuda
Looks like aftermarket aluminum pulleys. Is the water pump being under driven? What fan are you using? Oem or aftermarket? Clutch fan? Flex fan?
EDIT - On rereading your post I see you mentioned clutch fan.
[Re: 67_Satellite]
#2786167
06/16/20 10:14 PM
06/16/20 10:14 PM
Posts: 2,042 Leucadia, Ca.
vdriver
Leucadia, Ca.
I had the exact same issue with my '70 Duster 360 combo, and just took care of it yesterday.
I went to Home Depot and got a black cement mixing tub for about $5. The plastic it's made of is flexible enough that it follows the upper curve of the shroud easily. I cut a strip wide enough and long enough to cover the gap end to end. Screwed it down into the shroud with some stainless machine screws. This left a very small (1/8") second gap due to the weld along the top of the radiator, so I cut another strip to cover that. Probably could have left that little gap alone but it bugged me so I covered it. The pics tell the story. Obviously not a show car or factory restoration.
[Re: Chally1971]
#2786287
06/17/20 10:23 AM
06/17/20 10:23 AM
Posts: 144 Missouri
randavis
Missouri
I used some aluminum angle and used rivets to attach it.
74 Challenger, bought it new. In 1978 I replaced the original 318 with a 446 and 727. Mild cam, Jardine headers, and Holley Sniper EFI. New engine! 511" RB, Edelbrock Performer RPM heads, Eagle rotating assy, Comp hyd roller cam, Doug's 2" headers.
