Where do I start with the MSD Cam Syncronization #2785097
06/13/20 06:54 PM
06/13/20 06:54 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Just installed the MSD Cam syncronization in to my #1 spark plug and in to my Figital 7 7531 box.
Anyone use one of these and where did you start plotting in your MSD software on your laptop?
Re: Where do I start with the MSD Cam Syncronization [Re: Sammy] #2785297
06/14/20 10:53 AM
06/14/20 10:53 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Sorry, I can't be of any help but why do you need this?
Is that box capable of Coil near Plug ignition?
I guess I would check with MSD support to see if they can help.
Thanks!
Re: Where do I start with the MSD Cam Syncronization [Re: 340Cuda] #2785368
06/14/20 12:38 PM
06/14/20 12:38 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Thanks!
Because I want to pull timing out of certain hot cylinders for maximum ET & MPH.
Re: Where do I start with the MSD Cam Syncronization [Re: Sammy] #2785498
06/14/20 07:43 PM
06/14/20 07:43 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Hopefully MSD Tech help me out tomorrow and I dont get rushed off the phone
I figured that this isn't a popular add on and I knew I wasn't going to get much of a response. This one is definitely past my pay grade.
Re: Where do I start with the MSD Cam Syncronization [Re: Sammy] #2785539
06/14/20 09:48 PM
06/14/20 09:48 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
Well, the 1st thing is to go to rockauto and order about 40 plugs because every time you takeaway timing from a cylinder it gets a new plug. Not knowing what type of fuel system you have, so i not sure how much individual cylinder adjustment you have.
It's a lot of fun to play with but it might have been worth .02-.03 at most.
Joe
Without Data, you’re just another guy with an opinion.
Re: Where do I start with the MSD Cam Syncronization [Re: Sammy] #2785641
06/15/20 10:54 AM
06/15/20 10:54 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Thanks!
Thanks for the update, let us know what you find out and how it works.
Re: Where do I start with the MSD Cam Syncronization [Re: 340Cuda] #2785662
06/15/20 11:47 AM
06/15/20 11:47 AM
oregon
greendart408 Offline
oregon
I learned in short order that I needed this, lifted the head 2x's in about 10, 8th mile passes. I trenched the head and the last time the block too, on my f2 w8 deal. Brett M tried to tell me before I started......
Re: Where do I start with the MSD Cam Syncronization [Re: greendart408] #2785693
06/15/20 12:51 PM
06/15/20 12:51 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Same here. Brett warned me too.
