Where do I start with the MSD Cam Syncronization #2785097
06/13/20 06:54 PM
06/13/20 06:54 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Just installed the MSD Cam syncronization in to my #1 spark plug and in to my Figital 7 7531 box.
Anyone use one of these and where did you start plotting in your MSD software on your laptop?
Re: Where do I start with the MSD Cam Syncronization [Re: Sammy] #2785297
06/14/20 10:53 AM
06/14/20 10:53 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Sorry, I can't be of any help but why do you need this?
Is that box capable of Coil near Plug ignition?
I guess I would check with MSD support to see if they can help.
Thanks!
Re: Where do I start with the MSD Cam Syncronization [Re: 340Cuda] #2785368
06/14/20 12:38 PM
06/14/20 12:38 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Thanks!
Because I want to pull timing out of certain hot cylinders for maximum ET & MPH.
Re: Where do I start with the MSD Cam Syncronization [Re: Sammy] #2785498
06/14/20 07:43 PM
06/14/20 07:43 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Hopefully MSD Tech help me out tomorrow and I dont get rushed off the phone
I figured that this isn't a popular add on and I knew I wasn't going to get much of a response. This one is definitely past my pay grade.
Re: Where do I start with the MSD Cam Syncronization [Re: Sammy] #2785539
06/14/20 09:48 PM
06/14/20 09:48 PM
Central TEXAS!!!!
sr4440 Online content
sr4440  Online Content
Central TEXAS!!!!
Well, the 1st thing is to go to rockauto and order about 40 plugs because every time you takeaway timing from a cylinder it gets a new plug. Not knowing what type of fuel system you have, so i not sure how much individual cylinder adjustment you have.
It's a lot of fun to play with but it might have been worth .02-.03 at most.
Joe
Without Data, you’re just another guy with an opinion.
Re: Where do I start with the MSD Cam Syncronization [Re: Sammy] #2785641
06/15/20 10:54 AM
06/15/20 10:54 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Thanks!
Thanks for the update, let us know what you find out and how it works.
Re: Where do I start with the MSD Cam Syncronization [Re: 340Cuda] #2785662
06/15/20 11:47 AM
06/15/20 11:47 AM
oregon
greendart408 Offline
oregon
I learned in short order that I needed this, lifted the head 2x's in about 10, 8th mile passes. I trenched the head and the last time the block too, on my f2 w8 deal. Brett M tried to tell me before I started......
Re: Where do I start with the MSD Cam Syncronization [Re: greendart408] #2785693
06/15/20 12:51 PM
06/15/20 12:51 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Same here. Brett warned me too.
