Re: Where do I start with the MSD Cam Syncronization
[Re: 340Cuda]
#2785368
06/14/20 12:38 PM
06/14/20 12:38 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Sorry, I can't be of any help but why do you need this?
Is that box capable of Coil near Plug ignition?
I guess I would check with MSD support to see if they can help.
Thanks! Because I want to pull timing out of certain hot cylinders for maximum ET & MPH.
[Re: Sammy]
#2785539
06/14/20 09:48 PM
06/14/20 09:48 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Well, the 1st thing is to go to rockauto and order about 40 plugs because every time you takeaway timing from a cylinder it gets a new plug. Not knowing what type of fuel system you have, so i not sure how much individual cylinder adjustment you have. It's a lot of fun to play with but it might have been worth .02-.03 at most.
Joe
Without Data, you’re just another guy with an opinion.
[Re: Sammy]
#2785641
06/15/20 10:54 AM
06/15/20 10:54 AM
Posts: 3,518 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Thanks! Because I want to pull timing out of certain hot cylinders for maximum ET & MPH. Thanks for the update, let us know what you find out and how it works.
[Re: greendart408]
#2785693
06/15/20 12:51 PM
06/15/20 12:51 PM
Sammy
Wind Gap,Pa.
I learned in short order that I needed this, lifted the head 2x's in about 10, 8th mile passes. I trenched the head and the last time the block too, on my f2 w8 deal. Brett M tried to tell me before I started...... Same here. Brett warned me too.
