Who to call for solid roller cam #2783647
06/10/20 12:50 PM
06/10/20 12:50 PM
bigfork mn
dragram440 Offline OP
bigfork mn
I am putting a new set of Trick Flow power port 270 heads on my 500 CI RB and need to have someone spec a cam for me. I bought a used one and it doesn't seem to fit. The bearings seem to be to tight. Weird thing is I have had 3 different cams in these exact bearings. I would assume the used one I bought is bent or not the right tolerance to start with. I was going to call Hughes engines. Any other suggestions? Thanks in advance.
67' charger 499 RB 10.57 at 127
Re: Who to call for solid roller cam [Re: dragram440] #2783648
06/10/20 12:52 PM
06/10/20 12:52 PM
tboomer Offline
tboomer  Offline
Dwayne Porter..He will fix ya up right! up
Re: Who to call for solid roller cam [Re: tboomer] #2783663
06/10/20 01:07 PM
06/10/20 01:07 PM
Morrow, OH
markz528 Online content
markz528  Online Content
Morrow, OH
What block are you using?
Re: Who to call for solid roller cam [Re: markz528] #2783666
06/10/20 01:10 PM
06/10/20 01:10 PM
bigfork mn
bigfork mn
Stock 1969 440 block. Same block i have been running the last 8 years with this 500" setup.
Re: Who to call for solid roller cam [Re: dragram440] #2783669
06/10/20 01:11 PM
06/10/20 01:11 PM
I'm sure Dwayne is good but you might want to call Bullet Cams,662-893-5670 or Ultradyne cams at 662-893-8022. They are in the same shop so either one should be able to help you on getting a good cam, they are Mopar specialists also up
Re: Who to call for solid roller cam [Re: dragram440] #2783671
06/10/20 01:13 PM
06/10/20 01:13 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I use Scott Brown for any camshaft …..
IF you have cams that spin and one that doesn't? sounds like that cam may be a lil bent???. Usually if the bearings are new, they may be a little tight and need a scraping here and there, BUT that should be with any cam, not just one.
Good luck
....BAD A$$ STREET CAR.....
Re: Who to call for solid roller cam [Re: n20mstr] #2783732
06/10/20 02:52 PM
06/10/20 02:52 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
With no disrespect to Dwayne, I like my Scott Brown cam. Now all my head work will go to Dwayne...
69 GTX 68 Road Runner
Re: Who to call for solid roller cam [Re: JERICOGTX] #2783738
06/10/20 02:59 PM
06/10/20 02:59 PM
bigfork mn
bigfork mn
How do I get a hold of Scott Brown? Not finding anything googling it.
Re: Who to call for solid roller cam [Re: dragram440] #2783762
06/10/20 03:50 PM
06/10/20 03:50 PM
N
n20mstr Offline
n20mstr  Offline
N
BUYRACINGPARTS.COM
COMPETITION COPMONENTS
Re: Who to call for solid roller cam [Re: n20mstr] #2783802
06/10/20 05:41 PM
06/10/20 05:41 PM
New York, USA
Chargerfan68 Offline
New York, USA
No question....Dwayne Porter for all and any camshafts!!
Re: Who to call for solid roller cam [Re: dragram440] #2783842
06/10/20 07:25 PM
06/10/20 07:25 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I would call Dwayne Porter . up
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Who to call for solid roller cam [Re: Hemi Allstate] #2783914
06/10/20 10:11 PM
06/10/20 10:11 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I would call Billy Godbold at Comp Cams. I would bet he has the latest designs.
Floyd Lippencott IV
Re: Who to call for solid roller cam [Re: dragram440] #2783934
06/10/20 10:54 PM
06/10/20 10:54 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Whats the compression ratio?
Re: Who to call for solid roller cam [Re: mopar dave] #2783940
06/10/20 11:22 PM
06/10/20 11:22 PM
bigfork mn
bigfork mn
12.25-1 i might have the heads decked to get the chambers down a little. Trick flow 270 heads
Re: Who to call for solid roller cam [Re: dragram440] #2784008
06/11/20 09:32 AM
06/11/20 09:32 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
street/strip I assume. I would take a look at the solid comp roller cam dragula is using in his race car. 270/278 110 23-000-9. Not sure how agressive it is. That really looks like a nice cam if ya want to make max power. Bullet has the old UD Harold cam grinds that were designed by the best in the business with aggressive ramps too or Lunati voodoo line, they were Harolds designs as well. Isky makes nice grinds too, but I couldn't get then to spend much time with me. Here's another Bullet/Harold Brookshire grind i'm looking at 269/275 688/645 108. If your looking for a cam that makes your valve train happy and long lasting call Dwayne. My current cam 270/275 is a SLF mild lobe, easy on valve train and in my 511 street/strip car going 10 O's. It all depends on what your doing.
Re: Who to call for solid roller cam [Re: mr_340] #2784012
06/11/20 09:40 AM
06/11/20 09:40 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Funny thing about calling cam companies,,,,,called Comp for instance 5 times and got 6 different cams.
My next cam would be spec'd by Dwayne! It's all about the combination!!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Who to call for solid roller cam [Re: dragram440] #2784018
06/11/20 09:54 AM
06/11/20 09:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I ran a Scott Brown cam for a few years.. that cam was just down right WRONG for my set up
and he speced it out and I didnt like the 112 center line which he really likes.. if this is a race
set up you would be better off with Ultridyne
wave
Re: Who to call for solid roller cam [Re: hemi-itis] #2784023
06/11/20 10:12 AM
06/11/20 10:12 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Been there done that. Every cam guy has his own personal idea of what he thinks is needed and that's why we get those results and comp is not the best place to call for a cam spec. I agree, a matching combo is everything. If Harold was still around you would get the cam that made the most power and was as easy on valve train as possible. Some cam guys are very conservative and some are not. Harold was not conservative and still has some great old grinds.
Re: Who to call for solid roller cam [Re: MR_P_BODY] #2784025
06/11/20 10:13 AM
06/11/20 10:13 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I agree, my Scott Brown cam was way off with the 112LDA. My car couldn't get out of its own smoke with that cam.
Re: Who to call for solid roller cam [Re: hemi-itis] #2784040
06/11/20 11:06 AM
06/11/20 11:06 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
And why Isky is the best overall in MY world and all I use plus my roller has the most aggressive street-ish lobes while being easy on parts. 14+ years and changed springs twice and rebuilt the roller lifters once so far. Easy mid 9's and 6-teens so far and driven a good amount.......680-.660 276-281 on a 108 lsa w/97 degrees of overlap.....
