Deformed '70 'Cuda Tail Light Bezels #2781560
06/04/20 11:20 PM
06/04/20 11:20 PM
Salem
Grizzly Offline OP
Moparts Proctologist
Grizzly  Offline OP
Salem
Is it possible to straighten '70 'Cuda saggy tail light bezels?
I looked for a decent used set but even the "mint" ones are sagged across the top.
Mo' Farts
Moderated by "tbagger".
Re: Deformed '70 'Cuda Tail Light Bezels [Re: Grizzly] #2781588
06/05/20 04:43 AM
06/05/20 04:43 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Very common, not sure I've ever restored a 70 that didn't need the outer bezels bumped around, you can work them by hand pretty easily.
Re: Deformed '70 'Cuda Tail Light Bezels [Re: HEMICUDA] #2781832
06/05/20 06:06 PM
06/05/20 06:06 PM
Alabama
David1971 Offline
David1971  Offline
Alabama
Is one sagging this much salvageable?
David
Re: Deformed '70 'Cuda Tail Light Bezels [Re: David1971] #2781979
06/06/20 06:14 AM
06/06/20 06:14 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Yea, I've moved them that far, besides, what do you have to loose?
Re: Deformed '70 'Cuda Tail Light Bezels [Re: HEMICUDA] #2782007
06/06/20 08:50 AM
06/06/20 08:50 AM
moparx Online content
moparx  Online Content
what causes that ?
beer
Re: Deformed '70 'Cuda Tail Light Bezels [Re: moparx] #2782031
06/06/20 10:12 AM
06/06/20 10:12 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Originally Posted by moparx
what causes that ?
beer
A mismatch in length between the bezel post and something on the assembly (forget what and don’t have a pic, dang it)
Once you straighten it pay special attention during reassembly, find where the preload is being applied and clear it, won’t happen again
I bet Mike has a pic of the area that needs cleared.
Re: Deformed '70 'Cuda Tail Light Bezels [Re: AAR#2] #2782415
06/07/20 02:56 PM
06/07/20 02:56 PM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
what causes that ?
beer
You know, I've never looked at it that way, there just might be something to do with that. Just like the potmetal tail light bezels that warp, the side marker bezels have the same issue. Ever try to remove original lenses from side markers and the opening is closed up enough they won't come out? I've had to work the lengths of the side markers bezels to get them straight again.
Re: Deformed '70 'Cuda Tail Light Bezels [Re: HEMICUDA] #2782452
06/07/20 04:59 PM
06/07/20 04:59 PM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
Interesting.
I always thought it was the sun on the flat black that ruined them..
Mo' Farts
Re: Deformed '70 'Cuda Tail Light Bezels [Re: Grizzly] #2782587
06/07/20 11:21 PM
06/07/20 11:21 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
So been thinking about this and again, from memory, so if off don’t be a hater, my mind may not be as sharp as I believe it to be.
The bezel is what holds the studs, and once straightened the studs rode the tail lamp housing holes tight. When you assemble them, I recall being able to get the studs started but when you would tighten the fasteners, the tighter you got the more it wanted to bend the bezel back to a warped condition. Pretty sure I was forced to clear the tail lamp housing holes a bit to be able to correct the condition.
Re: Deformed '70 'Cuda Tail Light Bezels [Re: AAR#2] #2782683
06/08/20 11:09 AM
06/08/20 11:09 AM
Washington
hemienvy Offline
hemienvy  Offline
Washington
How do you bend them back, with a rubber mallet ?
Re: Deformed '70 'Cuda Tail Light Bezels [Re: hemienvy] #2783026
06/08/20 09:17 PM
06/08/20 09:17 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
I worked mine by hand, don’t be overly aggressive
Re: Deformed '70 'Cuda Tail Light Bezels [Re: AAR#2] #2783260
06/09/20 02:57 PM
06/09/20 02:57 PM
robertop Offline
robertop  Offline
I don't have a cuda, but in general I would do this: heat the warped areas gently with a heat gun then see how the area in question can be straightened by hand and, if so, fit the light assembly into it and let the area cool, maybe overnight, and then see if the warp is gone. You might have to do this more than once, just be careful not to heat the part too much. It should be not too hot to handle.
