Deformed '70 'Cuda Tail Light Bezels
#2781560
06/04/20 11:20 PM
06/04/20 11:20 PM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Is it possible to straighten '70 'Cuda saggy tail light bezels?
I looked for a decent used set but even the "mint" ones are sagged across the top.
Mo' Farts
Moderated by "tbagger".
Re: Deformed '70 'Cuda Tail Light Bezels
[Re: Grizzly]
#2781588
06/05/20 04:43 AM
06/05/20 04:43 AM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
I looked for a decent used set but even the "mint" ones are sagged across the top. Very common, not sure I've ever restored a 70 that didn't need the outer bezels bumped around, you can work them by hand pretty easily.
[Re: HEMICUDA]
#2781832
06/05/20 06:06 PM
06/05/20 06:06 PM
Posts: 203 Alabama
David1971
Alabama
I looked for a decent used set but even the "mint" ones are sagged across the top. Very common, not sure I've ever restored a 70 that didn't need the outer bezels bumped around, you can work them by hand pretty easily. Is one sagging this much salvageable? David
[Re: David1971]
#2781979
06/06/20 06:14 AM
06/06/20 06:14 AM
HEMICUDA
Medina, Ohio
Yea, I've moved them that far, besides, what do you have to loose?
[Re: moparx]
#2782031
06/06/20 10:12 AM
06/06/20 10:12 AM
Posts: 768 Dry Heat AZ
AAR#2
Dry Heat AZ
what causes that ? A mismatch in length between the bezel post and something on the assembly (forget what and don’t have a pic, dang it) Once you straighten it pay special attention during reassembly, find where the preload is being applied and clear it, won’t happen again I bet Mike has a pic of the area that needs cleared.
[Re: AAR#2]
#2782415
06/07/20 02:56 PM
06/07/20 02:56 PM
HEMICUDA
Medina, Ohio
what causes that ? A mismatch in length between the bezel post and something on the assembly (forget what and don’t have a pic, dang it) Once you straighten it pay special attention during reassembly, find where the preload is being applied and clear it, won’t happen again I bet Mike has a pic of the area that needs cleared. You know, I've never looked at it that way, there just might be something to do with that. Just like the potmetal tail light bezels that warp, the side marker bezels have the same issue. Ever try to remove original lenses from side markers and the opening is closed up enough they won't come out? I've had to work the lengths of the side markers bezels to get them straight again.
[Re: HEMICUDA]
#2782452
06/07/20 04:59 PM
06/07/20 04:59 PM
Posts: 6,003 Salem
Grizzly
Salem
Interesting.
I always thought it was the sun on the flat black that ruined them..
Mo' Farts
