Modern Air Conditioning, Anybody? #2780536
06/01/20 10:39 PM
06/01/20 10:39 PM
Berlin, CT
SportFuryS/23383 Offline OP
Confused
Confused
Berlin, CT
Hi All,
As some of you may know my stepfather is building a 1966 Dodge Charger with a big block 383, here is the build thread if anyone wants to follow it. https://board.moparts.org/ubbthread...s-1966-dodge-charger-restification.html. We have the engine mainly together and basically all we have left is the air conditioning, condenser, and radiator. I maybe missing a couple of things, anyway our plan is to put modern air conditioning in and NOT use the big and heavy RV2 to save a bit of weight and get cooler air. We are thinking of buying the Stage 2 Performance Kit from Original Air for $850.00, here is a picture and the link. We are looking for suggestions opinions and what have you about modern air conditioning prices and such, is there anything a bit cheaper than $850.00 with what we are looking for. Anybody? Any help, knowledge etc would be greatly appreciated. Thanks in advance everyone
https://www.originalair.com/66-70-b...0-134a-engine-compartment-upgrade-kit-stage-2
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher
Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
Re: Modern Air Conditioning, Anybody? [Re: SportFuryS/23383] #2780538
06/01/20 10:50 PM
06/01/20 10:50 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Originally Posted by SportFuryS/23383
Hi All,
I used about the same on my 68 Charger, rebuilt the factory ac/heater box, it will FREEZE you out, even when its 110deg outside.
Re: Modern Air Conditioning, Anybody? [Re: CSK] #2780579
06/02/20 08:09 AM
06/02/20 08:09 AM
Andrewh Offline
Andrewh  Offline
I think it depends on a few things.
Do you have the original inside box and controls?
IF so the under hood kit is the way to go.
however I don't think this is a great deal.
It is very complete however.
If you are able to piece together parts yourself, and get hoses made, it might be cheaper with one of the other well known kit makers like classic auto air or vintage air for just the underhood parts ordered separately.
you may have to call about the mount to the engine.
condensor for 150, compressor for 250, I am not sure all those odds and ends equal another 400 bucks. but could be wrong.
Re: Modern Air Conditioning, Anybody? [Re: Andrewh] #2780588
06/02/20 08:54 AM
06/02/20 08:54 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Call the makers and ask if it will fit an A/C car. I was going to scrap the A/C in my 68 Valiant but I come to find out none of the existing holes in the firewall were usable and there is no kit to replace the push button vacuum controls so I kept the old system and went new under hood. The aftermarket is geared up for non A/C cars at least in the A body so call first.
1969 Hemi Roadrunner 2nd owner
Re: Modern Air Conditioning, Anybody? [Re: 69hemibeep] #2780644
06/02/20 11:12 AM
06/02/20 11:12 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
An aftermarket AC system that will FREEZE YOU OUT ?
I’ve got a bud that’s building a Willy’s that would love that option!
Any aftermarket AC system we’ve ever seen is MORE than lacking tsk
Re: Modern Air Conditioning, Anybody? [Re: dOoC] #2780648
06/02/20 11:20 AM
06/02/20 11:20 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Then you haven't seen many aftermarket A/C systems.
'63 Dodge 330
11.19 @ 121 mph
Re: Modern Air Conditioning, Anybody? [Re: GY3] #2780653
06/02/20 11:37 AM
06/02/20 11:37 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The AC brackets are most likely Bouchillon. I'm planning on a complete aftermarket system for my '67 Barracuda convertible, but may piece some of it together.
Re: Modern Air Conditioning, Anybody? [Re: dOoC] #2780679
06/02/20 12:26 PM
06/02/20 12:26 PM
Andrewh Offline
Andrewh  Offline
I think you missed where he used the original under dash part.
Doing that I agree, the compressor doesn't make that much of a difference.
The under dash part makes it freeze you out. not the under hood, assuming you have a big enough condenser.
Re: Modern Air Conditioning, Anybody? [Re: Jim_Lusk] #2780717
06/02/20 01:50 PM
06/02/20 01:50 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I used a Vintage Air GenV evaporator and matching in-dash electronic controller and pieced together an under hood set-up from Nostalgic A/C on my 5.9 Magnum based motor with factory serpentine belt drive. It works very well an fit nicely, as. Vintage Air does not offer an A-Body kit as of yet.
I used the largest condenser that would fit in front of my radiator and had a local shop fit and crimp my A/C lines.
Re: Modern Air Conditioning, Anybody? [Re: jbc426] #2780722
06/02/20 01:59 PM
06/02/20 01:59 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Hay guyz ... hardly an automobile AC expert here AT ALL but I’ve ridden in enuff cars with AC and nothing I’ve ever come across would freeze you out..... other than my uncles turbo diesel Jetta eek
My 2020 Charger works well - no complaints - but a freeze out job ? ... nOpE ! tsk
Re: Modern Air Conditioning, Anybody? [Re: dOoC] #2780737
06/02/20 02:23 PM
06/02/20 02:23 PM
Andrewh Offline
Andrewh  Offline
lol, I have seen ice fly out of the vents in an 89 hyundai, so your wrong.
Re: Modern Air Conditioning, Anybody? [Re: Andrewh] #2780745
06/02/20 02:35 PM
06/02/20 02:35 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
tsk running the AC on MAX in the middle of winter up in Canuckada .....
Does NOT count !
Re: Modern Air Conditioning, Anybody? [Re: dOoC] #2780767
06/02/20 03:08 PM
06/02/20 03:08 PM
Andrewh Offline
Andrewh  Offline
max a/c in florida so stirthepot
Re: Modern Air Conditioning, Anybody? [Re: Andrewh] #2780774
06/02/20 03:15 PM
06/02/20 03:15 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Likely story ... tsk
Maybe when the orange trees FROZE in Eustis some time ago ! coffee
Re: Modern Air Conditioning, Anybody? [Re: dOoC] #2780782
06/02/20 03:37 PM
06/02/20 03:37 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If your buddy has room for a VintageAir MK IV under the dash, it should keep him adequately refrigerated. I have one in my Polara wagon and it will make you reach for the low cool.
Kevin
Re: Modern Air Conditioning, Anybody? [Re: dOoC] #2780813
06/02/20 05:15 PM
06/02/20 05:15 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
You have not rode in my 68 Charger LMAO, have you seen how large the evaporator is in a stock Charger, its HUGE , about 2.5 tons smile yes it will freeze you out
Re: Modern Air Conditioning, Anybody? [Re: CSK] #2780816
06/02/20 05:30 PM
06/02/20 05:30 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I used mostly Vintage Air system in a 1970 Cuda, ( hemi auto ) All the underdash components are electronic versus the old cable or vacuum controls. I made adapter brackets to mount the under dash box to existing non air heater box mounting points in case the owner ever decides to go back to stock ( not likely )
Not sure where the owner got the under hood stuff from .
The car is limelight green black vinyl top and all black interior. I wouldn't say it will freeze you out, but its close .
If I was ever to build another car for myself ( not likely ) And its not a factory air car, it will get the Vintage air system
Re: Modern Air Conditioning, Anybody? [Re: gtx6970] #2780829
06/02/20 05:50 PM
06/02/20 05:50 PM
Berlin, CT
Confused
Confused
Berlin, CT
Does anyone know of any places that sells what I am looking for cheaper than $850? We would spend it if we have to but we would like to find something cheaper as $850 is a bit much.
Re: Modern Air Conditioning, Anybody? [Re: Jim_Lusk] #2780830
06/02/20 05:51 PM
06/02/20 05:51 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Check with them ^^^^^^^
Re: Modern Air Conditioning, Anybody? [Re: SportFuryS/23383] #2780895
06/02/20 09:03 PM
06/02/20 09:03 PM
Andrewh Offline
Andrewh  Offline
everything there is probably off the shelf except the mount.
if you are willing to do the leg work you can probably piece it together a couple hundred cheaper.
but they put it in a kit and cut hoses to length.
I did the classic kit and it cost me 50 bucks to get the hoses cut and crimped while I waited.
if you need a kit, then I am not sure if you are going to find it much cheaper.
As mentioned the other 2 big names are vintage air and classic auto air.
