Recipe #2778610
05/27/20 09:15 AM
05/27/20 09:15 AM
Martinsville, IN
cdwmotorsports Offline OP
Martinsville, IN
I am wondering if there is a "recipe" for a 512 (400 block) . I want to drop my block off but want parts lined up to get the machining done properly. Thanks for the help
eBay-cdwmotorsports
Re: Recipe [Re: cdwmotorsports] #2778614
05/27/20 09:19 AM
05/27/20 09:19 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Pretty simple really. 4.25 crank, 6.535 rods and diamond and others have pistons off the shelf with different compression options depending on the cylinder heads used. We build them pretty often. Main bearing choice is a bit limited but the rods use a 2.2 pin so rod bearings are just like a chebby.
Todd
Re: Recipe [Re: sasquatch] #2778616
05/27/20 09:23 AM
05/27/20 09:23 AM
Martinsville, IN
Martinsville, IN
What rods would be best for street?
I was looking at Eagle but they don't list a 6.535 rod for Mopar
eBay-cdwmotorsports
Re: Recipe [Re: cdwmotorsports] #2778623
05/27/20 09:35 AM
05/27/20 09:35 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Well, there's the easy way---
http://store.440source.com/Stroker-Kits/products/3/
Or you can pick your own parts from different manufacturers, if you'd rather go that route, and have a little more control
over it.
I'm more comfortable with the second method.
You want Big Block Chevy rods, you do not want rods for a Mopar.
Rich H.
Esse Quam Videri
Re: Recipe [Re: ZIPPY] #2778625
05/27/20 09:42 AM
05/27/20 09:42 AM
Martinsville, IN
Martinsville, IN
Is there a brand preference for rods? Eagle, Oliver, SCAT? or are they pretty much all good
What manufacturers are used in the 440 Source kit? I dont see them listed
eBay-cdwmotorsports
Re: Recipe [Re: cdwmotorsports] #2778628
05/27/20 09:47 AM
05/27/20 09:47 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Well Oliver is in a different league. Price wise WAY different league but Scat, Eagle Molnar and others can all be used. I try to keep the rods and cranks from the same vendor just to make sure the width of the rods matches the journal.
Todd
Re: Recipe [Re: sasquatch] #2778700
05/27/20 12:02 PM
05/27/20 12:02 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Todd
Oliver is not what it used to be according to a couple people I trust.
The price has held up better than the quality standards.
Molnar kits are pretty nice......you still need to source pistons , but they are available from quality manufacturers.
Re: Recipe [Re: cdwmotorsports] #2778748
05/27/20 02:16 PM
05/27/20 02:16 PM
Molnar crankshaft with 4.250 stroke with BB Chevy rod journal size, 6.700 long BB Chevy type rods and have him get you the pistons also up
1-616-940-4640. ask for Tom and tell him I recommend them.
Cab
