Page 1 of 5 1 2 3 4 5
Anything wrong with a Fram PH8a for racecar? #2777032
05/22/20 01:55 PM
05/22/20 01:55 PM
Penna
70satelliteguy Offline OP
Penna
Any problems?
Re: Anything wrong with a Fram PH8a for racecar? [Re: 70satelliteguy] #2777036
05/22/20 02:01 PM
05/22/20 02:01 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The orange canister of death ..
Napa gold , or Wix for me
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Anything wrong with a Fram PH8a for racecar? [Re: 70satelliteguy] #2777051
05/22/20 02:28 PM
05/22/20 02:28 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Originally Posted by 70satelliteguy
Any problems?
Everything.
If you want to use a Fram, use an HP-1. Otherwise, don't bother.
Re: Anything wrong with a Fram PH8a for racecar? [Re: sixpakdodge] #2777061
05/22/20 02:48 PM
05/22/20 02:48 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Not even on a lawn mower. Are you new? That's like Crap to Avoid Like the Plague 101.
Re: Anything wrong with a Fram PH8a for racecar? [Re: CMcAllister] #2777067
05/22/20 02:55 PM
05/22/20 02:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With 1100+ post I hardly think he is new.... OP... use a Wix on it and dont worry
wave
Re: Anything wrong with a Fram PH8a for racecar? [Re: 70satelliteguy] #2777076
05/22/20 03:05 PM
05/22/20 03:05 PM
Kirkland, Washington
Pacnorthcuda Offline
Not even good for a boom-stick suppressor. Garbage. Throw it away, and never buy another.
Re: Anything wrong with a Fram PH8a for racecar? [Re: Pacnorthcuda] #2777110
05/22/20 04:45 PM
05/22/20 04:45 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
Day- ummmm .....
Re: Anything wrong with a Fram PH8a for racecar? [Re: Pacnorthcuda] #2777139
05/22/20 06:27 PM
05/22/20 06:27 PM
gregsdart Online content
gregsdart  Online Content
Wix 51515 for a bigblock race motor.
Re: Anything wrong with a Fram PH8a for racecar? [Re: 70satelliteguy] #2777140
05/22/20 06:27 PM
05/22/20 06:27 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I know they are expensive, but for a race car I like something like a System One filter, it is cleanable, easy to check and see if your engine is making metal, super heavy duty housing never have to worry about them bursting, and eventually it will pay for itself because you never have to buy another filter. On 340's they give you more header clearance. Usually they pick up the oil pressure slightly as well.
Plus you can say you are protecting the environment, no more oily filters in the landfill.
Re: Anything wrong with a Fram PH8a for racecar? [Re: 70satelliteguy] #2777147
05/22/20 06:49 PM
05/22/20 06:49 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Any problems?
Nope.
My Dad has been running them since before I was born, and I've been running them my entire life.
We're in a good-sized town and everyone here runs Fram and believe Me: if there was a problem, the whole place would have heard about it. Race or no-race. twocents
I would have to classify the comments on here as baseless and ignorant.
Mo' Farts
Moderated by "tbagger".
Re: Anything wrong with a Fram PH8a for racecar? [Re: Grizzly] #2777153
05/22/20 06:59 PM
05/22/20 06:59 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Any problems?
Nope.
I had a Fram on my car and the oil pressure dropped to 10 psi and after checking things a friend
told me to change the filter.. the pressure came right back.. never used a Fram again..
my brother had his pressure fall off I told him to change the filter and it came back up
wave
Re: Anything wrong with a Fram PH8a for racecar? [Re: Grizzly] #2777157
05/22/20 07:08 PM
05/22/20 07:08 PM
Florida STAYcation
Florida STAYcation
grizz... Grizz..... GRIZZZZZZZ !
Yur gonna RILE UP some apimp here ! coffee ..... popcorn
Re: Anything wrong with a Fram PH8a for racecar? [Re: dOoC] #2777162
05/22/20 07:14 PM
05/22/20 07:14 PM
Penna
Penna
Ordered the Wix racing filter today. Seems I do recall there being issues with them but thought maybe they had fixed the problems.
Besides low pressure what else is the problem?
Thanks Mike
Re: Anything wrong with a Fram PH8a for racecar? [Re: 70satelliteguy] #2777168
05/22/20 07:41 PM
05/22/20 07:41 PM
WI. U.S.A.
DusTed74 Offline
DusTed74  Offline
WI. U.S.A.
Does anyone here have any issues with the Jomar filter.
Thanks................Ted
Re: Anything wrong with a Fram PH8a for racecar? [Re: 70satelliteguy] #2777169
05/22/20 07:47 PM
05/22/20 07:47 PM
Guitar Jones Offline
Thanks Mike
They are cheaply made pieces of poo. Search youtube for fram filter comparison. It's all you need to know.
Re: Anything wrong with a Fram PH8a for racecar? [Re: Guitar Jones] #2777177
05/22/20 08:07 PM
05/22/20 08:07 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If it can stand the pressure use it. All filters have a bypass made into them for a reason, free flowing. Get into the rpms and your high dollar filter ain’t doing squat. If it does stop up guess what happens, no oil pressure. Oil filters on a race car are useless imo since if something breaks you ain’t gonna get it shut off in time to keep the parts out of the pump. If it breaks real good it shuts its own self off after the flames and carnival ride. For iron particles, big magnets in the pan and other places where the oil flows freely, easy to check and clean. Aluminum, brass will not hurt anything, just imbed into the bearings. STREET is a whole nuther animal a good filter Is necessary for the many hours of slow speed running around. Tell me, how can dirt and grit get into your sealed up engine other than thru the carb?
Re: Anything wrong with a Fram PH8a for racecar? [Re: MR_P_BODY] #2777179
05/22/20 08:16 PM
05/22/20 08:16 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Any problems?
Nope.
wave
I too had lost 15 PSI on a Fram. Did not think much about it till I dropped all oil pressure at 6000 RPM going thru the traps and my Idiot light came on.
A fellow racer had a spare Wix 51515, Installed it and finished the night and drove home.
A few months later I changed oil and grabbed the last one off my shelf and installed it. In two weeks it too lost about 10 PSI. Pulled the first one out of the trash and cut it open. Found it was all smashed inside, cut the second one and it too was smashed just not as bad.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Anything wrong with a Fram PH8a for racecar? [Re: Dave_J] #2777186
05/22/20 08:27 PM
05/22/20 08:27 PM
Florida STAYcation
Florida STAYcation
deeJAY ... 15lb loss would indicate to me ON THE SURFACE.... that the filter is actually FILTERING... instead of going on bypass tsk... grin
Re: Anything wrong with a Fram PH8a for racecar? [Re: dOoC] #2777192
05/22/20 08:38 PM
05/22/20 08:38 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Wix 51515R for racing, Wix 51515 for the street.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Anything wrong with a Fram PH8a for racecar? [Re: Hemi_Joel] #2777194
05/22/20 08:42 PM
05/22/20 08:42 PM
Florida STAYcation
Florida STAYcation
NOW ONLY if we all had THE BANK of SOME PEOPLE on here ... whistling grin
