Re: trans question - problem 727
[Re: stumpy]
#2776733
05/21/20 01:07 PM
05/21/20 01:07 PM
Posts: 1,444 NEW JERSEY
dynamite
NEW JERSEY
Did that first. New oil and filter, but thanks for the input.
[Re: dynamite]
#2777085
05/22/20 03:22 PM
05/22/20 03:22 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I find it hard to believe that, even with a loose bushing, a converter would drain back enough in a "few minutes" to cause this problem. As suggested, check the line pressure.
[Re: dynamite]
#2777340
05/23/20 11:59 AM
05/23/20 11:59 AM
John_Kunkel
Rio Linda, CA
To clarify the OP, after sitting a few minutes and shifted to D and it won't move, then shifting to R does Reverse engage right away?
If so, it's a problem with the rear clutch.
[Re: dynamite]
#2778039
05/25/20 01:06 PM
05/25/20 01:06 PM
John_Kunkel
Rio Linda, CA
Pre-'67 input shaft is 19-spline, '67-later is 24-spline...so no interchange..
[Re: dynamite]
#2778720
05/27/20 12:46 PM
05/27/20 12:46 PM
John_Kunkel
Rio Linda, CA
A pic of the copper looking debris would help, but it doesn't sound good.
[Re: dynamite]
#2779053
05/28/20 12:40 PM
05/28/20 12:40 PM
John_Kunkel
Rio Linda, CA
Any debris in the pan larger than a grain of sand is bad news. Pull it.
