Page 1 of 3 1 2 3
Max wedge big block vs w2 small block #2775721
05/18/20 01:34 PM
05/18/20 01:34 PM
Fort Madison iowa
Moparpuller Offline OP
Fort Madison iowa
Hi new member long time reader
I am building a sled pulling truck that requires iron heads. Big blocks are limited to. 472ci but must run factory castings. I have a set of 286 heads with one being cracked and in need of welding. Small blocks are limited to 434ci and can run aftermarket heads but must be cast iron. I also have a couple sets of w2 heads Rpm would need to be run around 8,000 to 8,500. If going small block I would get a 48 degree block and heads. Which heads would make more power if ported and the rest of the combo is correct. Thanks Grant
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775726
05/18/20 01:45 PM
05/18/20 01:45 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
286 heads are kinda frail....... so I can’t see myself getting too excited about those in that application.
Are the replacement 518’s legal?
My suspicion is that the really sharp SB guys could probably get the W2’s to be as good or better than the typical ported MW heads.
What’s the block rule?
What heads are legal for the Chevies and Fords?
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775727
05/18/20 01:45 PM
05/18/20 01:45 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I would think a 650 horse deal wouldnt be out of the realm of possibility with well done W2 heads and the associated goodies( roller, compression, etc)
Not sure what a big block could make....
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Max wedge big block vs w2 small block [Re: B3422W5] #2775752
05/18/20 02:30 PM
05/18/20 02:30 PM
Fort Madison iowa
Fort Madison iowa
I think I could get away with the replacement heads not sure tho. They are changing the rules to allow big blocks to have an aftermarket block as well. It was small block only for aftermarket blocks. The big block fords run cast iron super cobra jets and there are a few that run really well. One is supposed to be around 900hp. Not sure on the chevys. One was dynod the other day and made over 800 but haven’t seen any other engines on the same dyno to compare it to
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775755
05/18/20 02:40 PM
05/18/20 02:40 PM
So. Burlington, Vt.
So. Burlington, Vt.
What can the other SB combos run for heads?
Dart iron heads? Any cc limitations?
Valve angle rule?
What’s the intake manifold rule?
Cam rule?
Carb rule?
Compression rule?
Fuel rule?
I think a 434 Ford with Cleveland 4bbl heads would be a good SB combo........ if you could find heads that weren’t already used up.
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775758
05/18/20 02:44 PM
05/18/20 02:44 PM
It ain't hard to make 725 to 775 HP on pump swill,850+ on race gas, with the right parts in a BB up
The big deal is getting a stock block to live at 8000 + RPM at WOT for more than 15 seconds work
On your deal a good 400 block is the only one I would consider using if you decide to build a BB twocents
Re: Max wedge big block vs w2 small block [Re: Cab_Burge] #2775760
05/18/20 02:51 PM
05/18/20 02:51 PM
Fort Madison iowa
Fort Madison iowa
They have to be cast iron heads is all. There is one small block Chevy that has darts on it. Not sure which ones they are. Everything else is big block. Any intake as long as it is cast and mass produced. No sheet metal intakes. Any camshaft and carb allowed other than a stretched dominator. I can run a normal 4500 tho. I do have a 400 block In tho shop. Any race gas is allowed other than alcohol
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775764
05/18/20 02:59 PM
05/18/20 02:59 PM
There use to be a set of cast iron 440-1 on here for sale scope
Buy them and then look at a 3.391 or 3.900 stroke crankshaft with a Indy 400-3 intake and a 1050 CFM or bigger dominator carb. and bore the 400 block to either 4.350 or 4.360 (make sure on the C.I. first, you may need a shorter stroke) and buy a good set of aluminum main caps with ARP studs, no girdle tsk shoot for 14.0 + to 1 compression ratio and a good set of rockers and pushrods and go have some fun up
The heads will need to flow at least 370 CFM at .700 lift, more air will make more power devil grin
Re: Max wedge big block vs w2 small block [Re: Cab_Burge] #2775772
05/18/20 03:26 PM
05/18/20 03:26 PM
Fort Madison iowa
Fort Madison iowa
The cast iron 440-1 are illegal. Big blocks must run factory castings. Any suggestions on porters if I went with the w2s now that shady dell is out of the picture?
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775786
05/18/20 03:45 PM
05/18/20 03:45 PM
So. Burlington, Vt.
So. Burlington, Vt.
Running a Mopar with those rules is definitely going at it the hard way.
Is the Ritter block legal for a SB?
You know they don’t make w2’s anymore, right?
So you’re looking at used, or some NOS someone might have on the shelf.
Re: Max wedge big block vs w2 small block [Re: fast68plymouth] #2775793
05/18/20 03:51 PM
05/18/20 03:51 PM
AndyF Offline
AndyF  Offline
I had a set of brand new W2 heads for sale on here for a long time. Nobody was interested on here but a local guy showed up one day and bought them. So they are out there but not much demand for them.
Re: Max wedge big block vs w2 small block [Re: fast68plymouth] #2775795
05/18/20 03:52 PM
05/18/20 03:52 PM
Fort Madison iowa
Fort Madison iowa
Yes it is legal. I already have a couple sets of w2s They seem to be easier to come by than max wedge heads
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775799
05/18/20 03:59 PM
05/18/20 03:59 PM
So. Burlington, Vt.
So. Burlington, Vt.
Might be worth a call to Kent to see if he has any connections for porting those w2’s.
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775801
05/18/20 04:01 PM
05/18/20 04:01 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Chad Speier out in Ft. Hays, KS ported a local guy's cast iron W2's. With a 340 block stroked to 418 he is making an easy 600 HP on pump gas.
'63 Dodge 330
11.19 @ 121 mph
Re: Max wedge big block vs w2 small block [Re: GY3] #2775808
05/18/20 04:11 PM
05/18/20 04:11 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Who to go for porting W2s is a tough one, most people don't want to mess with Iron heads these days. Mine were done by Ryan and he said they would support 700HP. I am in the area of 600 now with low(10:1) 91 octane compression.
I had a local cylinder head guy freshen up the Valve Job last winter and he liked and was impressed by the work Ryan had done, its too bad that whole deal went south.
68 Barracuda Formula S 340
Re: Max wedge big block vs w2 small block [Re: Bad340fish] #2775821
05/18/20 04:23 PM
05/18/20 04:23 PM
So. Burlington, Vt.
So. Burlington, Vt.
600-650hp from W2’s on a high compression stroker shouldn’t be that hard at all.
If it’s a pretty serious class........ I doubt that would be competitive though.
With all the stuff that’s available for SB and BB Chevies........ you should be able to build one of those that makes another 100hp....... just by shopping in the Summit catalog.
700-750hp from a 286 head or some W2’s is gonna take some work.
Re: Max wedge big block vs w2 small block [Re: fast68plymouth] #2775849
05/18/20 05:06 PM
05/18/20 05:06 PM
Fort Madison iowa
Fort Madison iowa
If I could be around 700 I would be happy. We can run a vac pump also to help squeeze the most out of it as possible. Rules state the engine must match the truck. I already have the chassis done so I’m stuck with Mopar powered which I would prefer anyways. I could step up to the pro stock class that allows aluminum heads and 485ci. My buddy runs a ford in that class with kaase p51s that makes 950 and is getting the new sr71s next year. They really limit the Mopar heads in that class as well. No b1s. So victors or indys would be the better choices for it.
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775855
05/18/20 05:10 PM
05/18/20 05:10 PM
So. Burlington, Vt.
So. Burlington, Vt.
I’m not really a SB guy, but with those rules...... I’d build the w2/Ritter SB before I went with 286 heads on a stock block.
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775857
05/18/20 05:17 PM
05/18/20 05:17 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Trying to get a handle on this. Bigblock's can't run the Indy cast iron 440-1 head but Smallblocks can run the cast iron W-2's?! shruggy
Call this guy: https://speierracingheads.com/index.html
He posts a lot of stuff in the Yellowbullet naturally aspirated tech section.
'63 Dodge 330
11.19 @ 121 mph
Re: Max wedge big block vs w2 small block [Re: GY3] #2775859
05/18/20 05:24 PM
05/18/20 05:24 PM
Fort Madison iowa
Fort Madison iowa
Yup big blocks must run factory castings. Small blocks can run aftermarket. Hemis are allowed for the big block but I don’t have the budget to do that. It’s supposed to be more of a budget minded class whereas the pro stock is a higher dollar class. We already get accused of cheating enough with the pro stock ford I help with. If the dodge runs good in its class I don’t want to hear about it.
Page 1 of 3 1 2 3
