1982Ram slang 6 4x4 V8 up grade
#2775546
05/17/20 07:19 PM
05/17/20 07:19 PM
Posts: 1,244 Eastern,NC
68GTS383
Eastern,NC
Re: 1982Ram slang 6 4x4 V8 up grade
[Re: 68GTS383]
#2775588
05/17/20 09:44 PM
05/17/20 09:44 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
[Re: Sniper]
#2776623
05/20/20 10:31 PM
05/20/20 10:31 PM
Posts: 20,195 Park Forest, IL
slantzilla
Park Forest, IL
You're gonna need pretty much everything between the core support to the transfer case. You may be able to use the alternator and starter off the Slant. The wiring should only need a couple tweeks. You will need V-8 mounts and brackets. Other than that it's a direct bolt in.
