1982Ram slang 6 4x4 V8 up grade
#2775546
05/17/20 07:19 PM
05/17/20 07:19 PM
Posts: 1,244 Eastern,NC
68GTS383
Eastern,NC
Re: 1982Ram slang 6 4x4 V8 up grade
[Re: 68GTS383]
#2775588
05/17/20 09:44 PM
05/17/20 09:44 PM
Guitar Jones
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Sniper]
#2776623
05/20/20 10:31 PM
05/20/20 10:31 PM
Posts: 20,177 Park Forest, IL
slantzilla
Park Forest, IL
You're gonna need pretty much everything between the core support to the transfer case. You may be able to use the alternator and starter off the Slant. The wiring should only need a couple tweeks. You will need V-8 mounts and brackets. Other than that it's a direct bolt in.
