Rebuilt 4-Speed, what are you guys using for gear oil? #2772608
05/08/20 08:13 PM
05/08/20 08:13 PM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
I was going to use 90W synthetic gear oil but wanted to hear from the experts. What are you guys using?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: RSI700VIPER] #2772624
05/08/20 09:24 PM
05/08/20 09:24 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Do not use synthetic lube the old style syncros's work better with plain old dino oil. Penzoil syncromesh works good and Jamie Passon has a special blend that works too.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: fourgearsavoy] #2772627
05/08/20 09:29 PM
05/08/20 09:29 PM
New York
rarefish Offline
rarefish  Offline
New York
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: rarefish] #2772632
05/08/20 09:48 PM
05/08/20 09:48 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Originally Posted by rarefish
Me too.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: 70sixpkrt] #2772633
05/08/20 09:55 PM
05/08/20 09:55 PM
Newark DE
Dogpro Offline
Dogpro  Offline
Newark DE
I also use the sta-lube but make sure you use gl4 most parts store gear oil is gl5 which can harm your syncro's
Lou P.
Newark DE
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: fourgearsavoy] #2772683
05/09/20 01:39 AM
05/09/20 01:39 AM
Cab_Burge Online work
Cab_Burge  Online Work
Originally Posted by fourgearsavoy
Do not use synthetic lube . Penzoil syncromesh works good.
Gus beer
iagree That is what I'm using now in my NP 833O.D. trans up
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: Cab_Burge] #2772730
05/09/20 08:15 AM
05/09/20 08:15 AM
md
mopars4ever Offline
mopars4ever  Offline
md
The Sta Lube says it`s 80w90. What is the weight of the Pennzoil syncromesh ?
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: mopars4ever] #2772739
05/09/20 08:58 AM
05/09/20 08:58 AM
NW New Jersey
NW New Jersey
I did a quick check on the internet and a few people are saying NOT to use Penzoil Syncromesh in cars made before 1992 while others love it. Same with Sta-Lube although I see more positive feedback. In 1992, I was using ATF in my A833s.
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: RSI700VIPER] #2772743
05/09/20 09:09 AM
05/09/20 09:09 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Penzoil Syncromesh No complaints in 3 A833"s for me
1969 Hemi Roadrunner 2nd owner
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: mopars4ever] #2772748
05/09/20 09:19 AM
05/09/20 09:19 AM
NW New Jersey
NW New Jersey
Found this on a site. The guy making this claim seems very knowledgeable based on other posts:
That is very true, greg.
We have had this discussion many times in this formum about Synchromesh vs synchromesh and I am surprised so many people have NOT done any searches before or researching before entering into these discussions.
Then there is Pennzoil Synchromesh, a brand of synchromesh fluid by Pennzoil, a 9.5 cSt (about 0W30 weight) MTL with a GL-4 addpack.
Then there are the GM Synchromesh fluids brand which are 10.5 cSt (about 5W30 weight) MTLs with a GL-4 addpack.
I developed this list to assist in the selection of synchromesh-type fluids so please help me understand what is so confusing about it?
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: RSI700VIPER] #2772752
05/09/20 09:25 AM
05/09/20 09:25 AM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
Penzoil syncromesh In Mine
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: 69hemibeep] #2773063
05/10/20 04:02 AM
05/10/20 04:02 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Why use such a light weight GEAR oil in these 4-speeds?
Ease of shifting?
Less gear friction?
Or it contains "syncro" in name?
Why not just heavy gear oil?
Not like many, if any, will be driving them in the winter.
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: PhillyRag] #2773086
05/10/20 09:02 AM
05/10/20 09:02 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
It shifts better and its not all that light when you consider the factory suggests ATF for cold climates.
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: 69hemibeep] #2773256
05/10/20 05:28 PM
05/10/20 05:28 PM
Minnesota
VcodeR/T Offline
VcodeR/T  Offline
Minnesota
Any 75W/80W-90 as long as it carries a GL-4 rating...NOT GL-5. We use Amsoil MTG in our shop and have exclusively for many years with ZERO issues.
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: 69hemibeep] #2773378
05/11/20 02:05 AM
05/11/20 02:05 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
They said ATF in later years as a "Band Aid" remedy to user complaints in cold weather of hard shifts. Of course: gear oil thickens in the cold, until driven only a few miles, then works fine. These weren't designed by Chrysler to "user friendly", but rather to transfer, and withstand, heavy loads They (Chrysler) weren't concerned about long-term (high mileage) effects (wear & tear). Sure: racing OK. Less frictional losses. But any geared power transfer unit (a833, rear axle) needs heavy gear oil for best lubrication properties.
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: PhillyRag] #2773412
05/11/20 09:13 AM
05/11/20 09:13 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
I'm going by what the Service manual suggests and they were under warranty. Is there a bulletin "They" put out saying ATF was not to be used?
Re: Rebuilt 4-Speed, what are you guys using for gear oil? [Re: 69hemibeep] #2773466
05/11/20 11:17 AM
05/11/20 11:17 AM
Rittman Ohio
Rittman Ohio
I don't know if any of you guys have driven a manual trans Honda before but they use straight 30 wt, engine oil in their transmissions. They shift perfect at any temp and last 300K without any work on them shruggy I haven't tried it in my stuff yet but I have added a quart of engine oil to Toyota truck transmissions before to aid in cold weather shifting issues.
Gus beer
64 Plymouth Savoy
Dana 60
