Rebuilt 4-Speed, what are you guys using for gear oil?
#2772608
05/08/20 08:13 PM
05/08/20 08:13 PM
Posts: 1,149 NW New Jersey
RSI700VIPER
NW New Jersey
I was going to use 90W synthetic gear oil but wanted to hear from the experts. What are you guys using?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5 1969 Daytona Charger 440 4-Speed, Dana, EV2 1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7 1970 340 Six Pack Callenger T/A 4-speed T8 Tan 1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth 1969 Talladega Torino, 428CJ 1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: Rebuilt 4-Speed, what are you guys using for gear oil?
[Re: RSI700VIPER]
#2772624
05/08/20 09:24 PM
05/08/20 09:24 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Do not use synthetic lube the old style syncros's work better with plain old dino oil. Penzoil syncromesh works good and Jamie Passon has a special blend that works too. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 70sixpkrt]
#2772633
05/08/20 09:55 PM
05/08/20 09:55 PM
Posts: 367 Newark DE
Dogpro
Newark DE
I also use the sta-lube but make sure you use gl4 most parts store gear oil is gl5 which can harm your syncro's
Lou P. Newark DE
[Re: fourgearsavoy]
#2772683
05/09/20 01:39 AM
05/09/20 01:39 AM
Posts: 43,141 Bend,OR USA
Cab_Burge
Do not use synthetic lube . Penzoil syncromesh works good. Gus That is what I'm using now in my NP 833O.D. trans
[Re: Cab_Burge]
#2772730
05/09/20 08:15 AM
05/09/20 08:15 AM
Posts: 13,574 md
mopars4ever
md
The Sta Lube says it`s 80w90. What is the weight of the Pennzoil syncromesh ?
[Re: mopars4ever]
#2772739
05/09/20 08:58 AM
05/09/20 08:58 AM
RSI700VIPER
NW New Jersey
I did a quick check on the internet and a few people are saying NOT to use Penzoil Syncromesh in cars made before 1992 while others love it. Same with Sta-Lube although I see more positive feedback. In 1992, I was using ATF in my A833s.
[Re: RSI700VIPER]
#2772743
05/09/20 09:09 AM
05/09/20 09:09 AM
Posts: 1,383 Az
69hemibeep
Az
Penzoil Syncromesh No complaints in 3 A833"s for me
1969 Hemi Roadrunner 2nd owner
[Re: mopars4ever]
#2772748
05/09/20 09:19 AM
05/09/20 09:19 AM
RSI700VIPER
NW New Jersey
The Sta Lube says it`s 80w90. What is the weight of the Pennzoil syncromesh ? Found this on a site. The guy making this claim seems very knowledgeable based on other posts: That is very true, greg.
We have had this discussion many times in this formum about Synchromesh vs synchromesh and I am surprised so many people have NOT done any searches before or researching before entering into these discussions.
Then there is Pennzoil Synchromesh, a brand of synchromesh fluid by Pennzoil, a 9.5 cSt (about 0W30 weight) MTL with a GL-4 addpack.
Then there are the GM Synchromesh fluids brand which are 10.5 cSt (about 5W30 weight) MTLs with a GL-4 addpack.
I developed this list to assist in the selection of synchromesh-type fluids so please help me understand what is so confusing about it?
[Re: 69hemibeep]
#2773063
05/10/20 04:02 AM
05/10/20 04:02 AM
Posts: 1,754 Phila
PhillyRag
Phila
Penzoil Syncromesh No complaints in 3 A833"s for me Why use such a light weight GEAR oil in these 4-speeds? Ease of shifting? Less gear friction? Or it contains "syncro" in name? Why not just heavy gear oil? Not like many, if any, will be driving them in the winter.
[Re: PhillyRag]
#2773086
05/10/20 09:02 AM
05/10/20 09:02 AM
Posts: 1,383 Az
69hemibeep
Az
It shifts better and its not all that light when you consider the factory suggests ATF for cold climates.
[Re: 69hemibeep]
#2773378
05/11/20 02:05 AM
05/11/20 02:05 AM
Posts: 1,754 Phila
PhillyRag
Phila
It shifts better and its not all that light when you consider the factory suggests ATF for cold climates. They said ATF in later years as a "Band Aid" remedy to user complaints in cold weather of hard shifts. Of course: gear oil thickens in the cold, until driven only a few miles, then works fine. These weren't designed by Chrysler to "user friendly", but rather to transfer, and withstand, heavy loads They (Chrysler) weren't concerned about long-term (high mileage) effects (wear & tear). Sure: racing OK. Less frictional losses. But any geared power transfer unit (a833, rear axle) needs heavy gear oil for best lubrication properties.
[Re: PhillyRag]
#2773412
05/11/20 09:13 AM
05/11/20 09:13 AM
Posts: 1,383 Az
69hemibeep
Az
It shifts better and its not all that light when you consider the factory suggests ATF for cold climates. They said ATF in later years as a "Band Aid" remedy to user complaints in cold weather of hard shifts. Of course: gear oil thickens in the cold, until driven only a few miles, then works fine. These weren't designed by Chrysler to "user friendly", but rather to transfer, and withstand, heavy loads They (Chrysler) weren't concerned about long-term (high mileage) effects (wear & tear). Sure: racing OK. Less frictional losses. But any geared power transfer unit (a833, rear axle) needs heavy gear oil for best lubrication properties. I'm going by what the Service manual suggests and they were under warranty. Is there a bulletin "They" put out saying ATF was not to be used?
[Re: 69hemibeep]
#2773466
05/11/20 11:17 AM
05/11/20 11:17 AM
fourgearsavoy
Rittman Ohio
I don't know if any of you guys have driven a manual trans Honda before but they use straight 30 wt, engine oil in their transmissions. They shift perfect at any temp and last 300K without any work on them I haven't tried it in my stuff yet but I have added a quart of engine oil to Toyota truck transmissions before to aid in cold weather shifting issues. Gus
