Trunk mat adhesive?
#2771504
05/05/20 04:53 PM
05/05/20 04:53 PM
Posts: 670 Third rock from the sun.
busboy
Got a piece of good jute backing that I’d like to glue to the trunk mat material. The mats come in vinyl (with a thin felt backing) or in rubber. I’d like to use the rubber for it’s durability. 3M and Dominion Seal make “trim adhesive” products that come in rattle cans, I’m just not sure what would stick to rubber. Also, would just good old contact cement brushed on work? Anybody done this? Any help much appreciated.
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Trunk mat adhesive?
[Re: busboy]
#2771560
05/05/20 07:36 PM
05/05/20 07:36 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
FYI; Back in 1978 when I bought my 'Cuda for $1000, I found moisture between the mat and the trunk floor, and the trunk floor had started to rust. I pulled it out, treated the rust and painted it. I never put a trunk mat back in there, which is why I still have my original trunk floor. Even when there's no rain, I often find moisture under them.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2771763
05/06/20 11:09 AM
05/06/20 11:09 AM
Posts: 4,723 Moved to N.E. Tennessee
GomangoCuda
FYI; Back in 1978 when I bought my 'Cuda for $1000, I found moisture between the mat and the trunk floor, and the trunk floor had started to rust. I pulled it out, treated the rust and painted it. I never put a trunk mat back in there, which is why I still have my original trunk floor. Even when there's no rain, I often find moisture under them. Same here. When I bought my Barracuda 20 years ago it didn't have a trunk mat so I bought one. A couple of weeks after putting it in the trunk I lifted a corner up and the floor was wet. That mat has been rolled up on a shelf since then.
[Re: GomangoCuda]
#2772451
05/08/20 01:13 PM
05/08/20 01:13 PM
busboy
Hmmmm... good points about the moisture in the trunk! Car has a new trunk seal so not worried about leaks and doesn’t live outside but you raise a good point. We do enjoy multi day road trips, my goal was to reduce any noise or rattles coming from stuff in the trunk. Sounds like the mat would have to come out/dry out between trips.
