walmart super tech trans fluid #2770857
05/03/20 05:42 PM
05/03/20 05:42 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
OK anyone use it?? Im doing a trans fluid change and i have 4 qts that have been sitting around for a while now.
....BAD A$$ STREET CAR.....
Re: walmart super tech trans fluid [Re: n20mstr] #2770858
05/03/20 05:46 PM
05/03/20 05:46 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I'v use it many of times, up no problem but I'm no expert either.
Re: walmart super tech trans fluid [Re: n20mstr] #2770871
05/03/20 06:17 PM
05/03/20 06:17 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I ran their Dextron 3 for years till I had an unrelated issue with a powerglide that led to me burning up my band. I switched back to type F that I ran years ago only because the Walmart Dextron 3 had a slightly burnt smell new right out of the jug. And that and that alone made it harder to diagnose my issue. My sons still using it in his 727.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: walmart super tech trans fluid [Re: pittsburghracer] #2770878
05/03/20 06:30 PM
05/03/20 06:30 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Been using the Type F Super Tech stuff in the dragster for years. Just had to have the case recertified and all looked good as new when taken apart. Has at least 7-800 passes on it, been changed a few times. It is in an FTI Glide, Reid cased glide that has had 700-1100 NA HP in front of it.
Re: walmart super tech trans fluid [Re: Al_Alguire] #2770880
05/03/20 06:41 PM
05/03/20 06:41 PM
PA.
"Little"John
"Little"John
PA.
Some of my stock
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: walmart super tech trans fluid [Re: n20mstr] #2770884
05/03/20 06:50 PM
05/03/20 06:50 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I just switched out the Walmart F type for ATI F type synthetic. Right after the fluid switch and a band adjustment I notice 200rpm increase in park warmed up and 100rpm in drive and also gain 100rpm increase in stall.
Re: walmart super tech trans fluid [Re: mopar dave] #2770901
05/03/20 07:59 PM
05/03/20 07:59 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
It's all I use.
My transmissions always get double the abuse being a street/strip car.
Never an issue.
'63 Dodge 330
11.19 @ 121 mph
Re: walmart super tech trans fluid [Re: GY3] #2770907
05/03/20 08:06 PM
05/03/20 08:06 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
I used the Type F in the forks of my bikes. Does that count?
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: walmart super tech trans fluid [Re: Dave_J] #2770994
05/04/20 07:21 AM
05/04/20 07:21 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have had no trouble with the wal mart type F.
68 Barracuda Formula S 340
Re: walmart super tech trans fluid [Re: Dave_J] #2770995
05/04/20 07:23 AM
05/04/20 07:23 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Been using Super Tech Type F for the last 8-10 years without any issues.
Re: walmart super tech trans fluid [Re: mopar dave] #2771010
05/04/20 09:15 AM
05/04/20 09:15 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
The Walmart fluid came out clean as can be and the bottom of the pan was as clean as I have ever seen after 2 seasons of running mostly street. Was pleasantly surprised I picked up the welcomed 100rpm in stall.
Re: walmart super tech trans fluid [Re: mopar dave] #2771061
05/04/20 11:35 AM
05/04/20 11:35 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Time to wait in line w/the rest of the sheeple and get me some of that stuff.......
Re: walmart super tech trans fluid [Re: mopar dave] #2771113
05/04/20 02:50 PM
05/04/20 02:50 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
And all that more than likely came from the viscosity of the ATI Super F, it comes in three different weights, not so much at Walmart
Re: walmart super tech trans fluid [Re: Al_Alguire] #2771129
05/04/20 03:59 PM
05/04/20 03:59 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Yeah, the Walmart stuff must be hard to pump to cost 200rpm idling in park .
Re: walmart super tech trans fluid [Re: DusterKid] #2771132
05/04/20 04:19 PM
05/04/20 04:19 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
I ran a Pro Trans 904 in my Aspen and they recommend Walmart type F for their trannies.
Raul
Re: walmart super tech trans fluid [Re: Aspen7695] #2771273
05/04/20 11:42 PM
05/04/20 11:42 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Super tec type F is 3.97 plus tax....you get free shipping with any order over 35 dollars....you dont have to stand in line...two day free shipping...
plus many times i have gone there and only a few quarts are on the shelf....order on line and get what you want without leaving the house
Tony
70 AARCuda Vitamin C
