904 front drum apply spring help needed #2767816
04/24/20 12:05 PM
04/24/20 12:05 PM
Central Mississippi
mopar97 Offline OP
mopar97  Offline OP
Central Mississippi
I am doing a Rebuild on my 1967 904. I have Mr. Toms book and it has helped a lot, I am actually using his recommendations from the appendix, but I still have a question about the single apply spring. I have a 5 disc front drum, but I have 3 springs, 1 from the 67, 1 from a 69, and one from a 999 which is where I got the steel 4 pinion planetary's. I have been all over looking for questions about this spring with no luck.
Is one any better than the other?
Yes I know of the aftermarket multi spring but that is not my question.
Thanks in advance for reading..
Mopar born, Mopar breed, when I die, call me Mopar dead!
Re: 904 front drum apply spring help needed [Re: mopar97] #2767836
04/24/20 01:00 PM
04/24/20 01:00 PM
A727Tflite Online content
A727Tflite  Online Content
Measure the wire diameters first.
Then the free lengths.
If they are the same wire diameter and close in free length then they are probably the same springs rates.
They were color coded in the plant so the builders could select the correct spring front the BOM for that can clutch.
If you have a valve spring tester you can test them in a vice for spring rate too.
It’s not which is better but which is required to match h the front servo lever and spring rate there - it affects 2-3 shift timing.
Re: 904 front drum apply spring help needed [Re: A727Tflite] #2767838
04/24/20 01:03 PM
04/24/20 01:03 PM
Central Mississippi
mopar97 Offline OP
mopar97  Offline OP
Central Mississippi
I have a 4.2 lever. The 999 spring is yellow, the other 2 are orangeish......how do I determine which is best for me?
Re: 904 front drum apply spring help needed [Re: mopar97] #2767890
04/24/20 04:40 PM
04/24/20 04:40 PM
Use orange spring/5 discs along with the 3.8 lever. You can try the 4.2 but install 4 discs. Install the inner KD servo spring and find an orange outer spring for the KD servo.
Yellow spring is for peanut motors and 2.5 lever.
Re: 904 front drum apply spring help needed [Re: A727Tflite] #2767903
04/24/20 05:53 PM
04/24/20 05:53 PM
Central Mississippi
mopar97 Offline OP
mopar97  Offline OP
Central Mississippi
Ok thanks, I will see if I have a 3.8 lever.
Re: 904 front drum apply spring help needed [Re: mopar97] #2767944
04/24/20 08:47 PM
04/24/20 08:47 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
http://www.atiracing.com/products/trans/904/index.htm
ati makes a replacement single wound spring for the 904.....
TF904 Reverse Wound Direct Drum Spring 20 bucks....
Tony
70 AARCuda Vitamin C
Re: 904 front drum apply spring help needed [Re: mopar97] #2769008
04/28/20 09:22 AM
04/28/20 09:22 AM
Central Mississippi
mopar97 Offline OP
mopar97  Offline OP
Central Mississippi
Thanks for the assistance. Hopefully I can see how good a job I have done here soon.... stupid virus
