904 front drum apply spring help needed
#2767816
04/24/20 12:05 PM
04/24/20 12:05 PM
Posts: 235 Central Mississippi
mopar97
Central Mississippi
I am doing a Rebuild on my 1967 904. I have Mr. Toms book and it has helped a lot, I am actually using his recommendations from the appendix, but I still have a question about the single apply spring. I have a 5 disc front drum, but I have 3 springs, 1 from the 67, 1 from a 69, and one from a 999 which is where I got the steel 4 pinion planetary's. I have been all over looking for questions about this spring with no luck. Is one any better than the other? Yes I know of the aftermarket multi spring but that is not my question. Thanks in advance for reading..
Mopar born, Mopar breed, when I die, call me Mopar dead!
Re: 904 front drum apply spring help needed
[Re: A727Tflite]
#2767838
04/24/20 01:03 PM
04/24/20 01:03 PM
mopar97
Central Mississippi
Thanks I have a 4.2 lever. The 999 spring is yellow, the other 2 are orangeish......how do I determine which is best for me?
[Re: A727Tflite]
#2767903
04/24/20 05:53 PM
04/24/20 05:53 PM
mopar97
Central Mississippi
Use orange spring/5 discs along with the 3.8 lever. You can try the 4.2 but install 4 discs. Install the inner KD servo spring and find an orange outer spring for the KD servo.
Yellow spring is for peanut motors and 2.5 lever. Ok thanks, I will see if I have a 3.8 lever.
[Re: mopar97]
#2767944
04/24/20 08:47 PM
04/24/20 08:47 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
http://www.atiracing.com/products/trans/904/index.htmati makes a replacement single wound spring for the 904..... TF904 Reverse Wound Direct Drum Spring 20 bucks....
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: mopar97]
#2769008
04/28/20 09:22 AM
04/28/20 09:22 AM
mopar97
Central Mississippi
Thanks for the assistance. Hopefully I can see how good a job I have done here soon.... stupid virus
