Which aluminum intake to retain AC on LA small block #2768220
04/25/20 06:42 PM
04/25/20 06:42 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
I am looking for an aluminum intake but I need to be able to keep the AC.
The Edelbrock Performer is the only intake I know of that has the offset thermostat location and the bracket bosses for the factory AC.
Have you guys ever used other intakes, WIEAND, Eddy Air Gap, or that Chinese made air gap, and been able to retain the AC.
How did you make it work?
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Which aluminum intake to retain AC on LA small block [Re: hp383] #2768254
04/25/20 08:21 PM
04/25/20 08:21 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I used the basic Eddy Performer for mine: 406" SB & Thermoquad.
Opened up the runners a little near the heads.
Stock AC & everything else fit without problems.
Re: Which aluminum intake to retain AC on LA small block [Re: topside] #2768263
04/25/20 08:55 PM
04/25/20 08:55 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Depends on what style AC compressor. If you have the C171 the only one I know that clears it is the Edelbrock Performer.
RV2 most any will clear.
Re: Which aluminum intake to retain AC on LA small block [Re: Sniper] #2768484
04/26/20 05:42 PM
04/26/20 05:42 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
we just released our small block ac serpentine belt kit. you can run any intake you want. and the kit uses all modern accessories like a sanden ac compressor. so you can shave some weight off the front end and not have to sacrifice any HP using a non optimal intake for the application.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Which aluminum intake to retain AC on LA small block [Re: hp383] #2768744
04/27/20 02:35 PM
04/27/20 02:35 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Torker II had offset thermostat. That's probably the easiest "Performance" one to find.
Several of the last generation M1 intakes had both offset thermostat housing
and provisions for the smaller stamped steel housing but AFAIK those part numbers are all killed off/only available used.
Rich H.
Esse Quam Videri
Re: Which aluminum intake to retain AC on LA small block [Re: ZIPPY] #2768759
04/27/20 03:43 PM
04/27/20 03:43 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Don't forget the Magnum intakes have yet another offset and I don;t know what clears those.
RV2 thermostat location, will not clear a C171
C171 thermostat location, also has the boss for the stock bracket in c171 applications.
Magnum thermostat location I dunno what it clears.
Re: Which aluminum intake to retain AC on LA small block [Re: Sniper] #2768859
04/27/20 08:32 PM
04/27/20 08:32 PM
GA
roadrunninMark Offline
GA
Jerry, do you have any more info on the small block serpentine kit? I went to your website looking for info/pics and I just see caps and stud girdles. Can you either post pics and info or make a new thread explaining the kit and if one needs to supply the modern accessories (and what vehicle to get them from)?
