Challenger windshield washer lines #2768185
04/25/20 05:07 PM
04/25/20 05:07 PM
Norway
General 68 Offline OP
Norway
Hi
Does anyone on here have pictures showing the oem routing for the windshield washer lines in a 1970 Challenger? R/T hood if that matters. The car I am working on is missing everything after the bottle😂
Re: Challenger windshield washer lines [Re: General 68] #2768301
04/25/20 11:33 PM
04/25/20 11:33 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Originally Posted by General 68
Hi
....here's the factory print for 70 Cuda/Challenger, if you need a certain section zoomed in let me know...
Mike
Re: Challenger windshield washer lines [Re: DAYCLONA] #2768321
04/26/20 03:20 AM
04/26/20 03:20 AM
Norway
Norway
That is great, Dayclona! Thank you! The scan is a little blurry, but I think I'll figure it out. I will take a look at it today and let you know if I need any more info😀
By the way: Do you happen to know where I should look for a download able wiring diagram for 1970 Challenger?
Re: Challenger windshield washer lines [Re: General 68] #2768346
04/26/20 09:19 AM
04/26/20 09:19 AM
BDW Offline
BDW  Offline
Re: Challenger windshield washer lines [Re: General 68] #2768402
04/26/20 12:22 PM
04/26/20 12:22 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I can zoom in on any section/text if needed, plus contrast the background if your curious about a certain section of the print...let me know
Mike
Re: Challenger windshield washer lines [Re: DAYCLONA] #2768493
04/26/20 06:15 PM
04/26/20 06:15 PM
Norway
Norway
Thanks both of you!👍👍
Thanks to your answers I have pretty much figured it out. I am still a little puzzled as when I hold the nozzles over their mounting holes the squirter hits a rib inn the hood. Are the squirter supposed to be bent sideways some? I should have the correct parts as they are labeled ut "70-74 E-body" and looks identical to the ones in the drawings you posted.
Re: Challenger windshield washer lines [Re: General 68] #2768495
04/26/20 06:32 PM
04/26/20 06:32 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
The squirters on my 70 are about 1/8 of an inch below the ribs....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Challenger windshield washer lines [Re: HemiRick] #2768619
04/27/20 12:39 AM
04/27/20 12:39 AM
Norway
Norway
Good info👍 But the squirt wil still hit a rib when fired😝
Re: Challenger windshield washer lines [Re: General 68] #2768662
04/27/20 08:20 AM
04/27/20 08:20 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Position the squirter JUST below the upper surface of the cowl/hood
so they won't get caught when washing the car and you'll be good.
Joe
Re: Challenger windshield washer lines [Re: jlatessa] #2768922
04/28/20 12:29 AM
04/28/20 12:29 AM
Norway
Norway
Ok. Thanks. Just need to bend thhe sideways to avoid fluid hitting the ribs. 😔
Re: Challenger windshield washer lines [Re: General 68] #2769045
04/28/20 11:05 AM
04/28/20 11:05 AM
moparx Offline
moparx  Offline
it was very common back in the day to have to adjust the squirter nozzles by slightly bending them on a lot of cars to get the spray pattern correct without hitting the ribs, be it hood or cowl mounting.
i had a homemade "tool" built out of thin wall tubing that snugly fit the nozzles so i could bend them up, down, and sideways until the spray pattern was where the driver wanted it, but it got lost over the years.
beer
